  3. Default map whe opening routes
4 Posts 2 Posters 913 Views
  • Lluis Arasanz
    I've found when opening routes in MRA made with Tom Tom map that, as normal user, it only can be opened with Openstreetmap.
    But, As MRA Navigation Lifetime user, I also have Here Maps available.
    Can be updated dialog to use maps available for user? If not, cycle is convert from Tom tom to Openstreet and then to Here... so many conversions.
    I know than Gold is better option, but meanwhile, if we can select map to use in conversion could be better.
    Best Regards!
    • BMW F750GS
    • Lluis Arasanz Lluis Arasanz
      Best Regards!
      @Lluis-Arasanz, I don't think that will ever happen. As a MyRoute-App Free user you don't get the TomTom map, nor the HERE map. As a Paying Navigation member you need the HERE map in your navigation app, so they add it to your planner too.
      Why would you want to plan your routes with the TomTom map?
        I want to use some routes created with TomoTom, and archived in a MRA group. I'm not planning those routes in TomTom
        My question is targeted to avoid unnecessary route changes for different map engine while try to maintain original route.
        Also, is oriented in unify Map engines available for a user based on licenses available.
        If not possible... no problem 😉
        • BMW F750GS
          @Lluis-Arasanz, the unifying map in the MRA ecosystem is exactly the HERE map. You can ask the planner of those routes if the routes are equalized using the tools available for Gold members. If so, you can be pretty sure the route loaded upon the HERE map will be consistent. The new NEXT app is able to navigate a track too. So you can also ask them for a track.
          • Map lock
            tfdahazellgmail.com
            tfdahazellgmail.com
          • Beta abonnement
            BMW1300GSA
            BMW1300GSA
            2.3k
            Gerard van der Veer
            Gerard van der Veer
          • Uitnodiging
            Hans Kremers
            Hans Kremers
          • SilverFox Controller C2
