  4. MRA Next without Testflight
4 Posts 2 Posters 124 Views
  • Tegel Werner
    is it possible to test MRA Next without Testflight?
    I allways use old iPhone for Navigation an my 6plus end on Version 12.5.7. If Understand this version works with MRA Next. But to test it's necessary to install TestFlight but this need IOS 14 to install. If anyone know to install MRA Next Beta without TestFlight let me know. For Corjan this will be a test on a iPhone which only Use for Navigation, with no connect to the business. Maybe the result will help you to improve the MRA Nest to a lower IOS.
    regards
    Bison
    • Tegel Werner Tegel Werner
      regards
      Bison
      @Tegel-Werner I’m sorry but TestFlight is required. You’d have to wait for the official release to be able to download the app as it’s now in Beta.
      This won’t however be the best experience. I believe the minimum version will eventually be iOS 13 and for CarPlay a minimum version of 14 will be required. These might however still change in the coming months as we aim to support the lowest versions possible without constraining ourselves.
      Tegel Werner 2 Replies Last reply
        Hi corjan I still hope that Information on the TestFlight Screen MRA Next works with IOS 12.4 or higher (in the German Version of TestFlight) cames true. So I can Use the old iPhone with all Bike Equipment (cradle etc). Okay is still wait.
        Regards Werner
          Hi Corjan I get this Information.
          MyRoute-app Mobile 3.2.11 (163) is ready to test on iOS.
          What to Test:
          • Improved logging to help us resolve battery usage and app stability issues
          • Use app with CarPlay without first opening the app on your phone
          • Better positioning of location indicator within CarPlay
          • CarPlay stability
          To test this app, open TestFlight on your iOS device using iOS 12.4 or later and install the update.
          Please change the Text to IOS 12.4 if you can install Test Flight which requires IOS 14.x.
          May be there is no disinformation about Testing with IOS 12.4
          Regards from Werner
          P.S. The next hardcore Test for MRA Next ist TT on Isle of Man.
            Lluís Casals
            Lluís Casals
