  4. Routing problem
Routing problem
3 Posts 2 Posters 58 Views
    I am not sure what the reason for this problem is, but it happens the scound time. I was about 30km north of home and used one of the favorite "Home", where my home address is.
    So normally a A to B route.
    But the calculation is as follows, see pic.!
    I should leave the Autobahn much earlier and have to drive over waypoint 1 that is not set by me.
    Or what is (1)?
    After pressing Start, the route can not be calculated and the App crashes.
    Error report was sent yesterday 11.03. about 20:00 via the App.
      Or what is (1)?
      @Jörgen thanks for sharing!
      That waypoint 1 indicates that the generated track (which you are using to drive) has a possible error at that location.
      This likely has to do with an error is the OSM calculation (which is used for to generate the tracks).
        This should be the normal way.
          Lluís Casals
          Lluís Casals
