  4. Voice guidance and sounds interfere with the car radio & music
4 Posts 4 Posters 93 Views
  • David Bonner
    David Bonner
    David Bonner
    If my phone is connected ( ie for charging ) in my car, with Navigation Next running, voice guidance and sounds interfere with the radio & music. Instead of of overlaying with what is playing, as other systems such as Google Maps do, Navigation guidance & sounds completely knock out the channel. It takes some time for the channel to recover, and sometimes it does not.
    Btw the previous Navigation had the same problem even when using CarpPay.
    However it may be a fault with my car, VW Golf mk7, rather than MRA, as I have not tested this in any other vehicle.
    Albert van den Elsen 1 Reply Last reply
      I have the same problem in a SEAT (also VW company) any audio from MRA N will interrupt the radio. I need to tap radio again to get the music back.
      It is a bug in MRA N. And I think it is known already.
        Indeed! Known issue which mainly occurs with external radio. When using Spotify / Apple Music etc.. while using our app the expected behaviour occurs.
        We will attempt to fix this in a later stage of development.
        • David Bonner David Bonner
          wrote on last edited by Albert van den Elsen
          @David-Bonner I have the same problem with my Pioneer radio. Every notification from MRA Nav next interupts ( turns off) the radio. Same as Jörgen I also need to tap radio again to get the music back.
          Friend of mine has the same problem.
          If I turn off all MRA Nav N notification my Radio keeps working.
          iPhone 15,
          Garmin Zumo XT3
          Carpuride W702 Pro
          Sena 20S EVO headset
          Harley Davidson Road King M8
          David Bonner
          David Bonner
            Lluís Casals
            Lluís Casals
