  3. ZUMO XT WHICH GPX EXPORT FORMAT?
5 Posts 3 Posters 1.3k Views
  • Giuseppe Marino
    Giuseppe Marino
    Giuseppe Marino
    What gpx export format do you use for your Zumo XT and why?
    Some users use the 1.0 export format, some use the 1.1 format, and still others use the 1.2 format. Could you tell me which format to use for the Zumo XT and why you use that format? Thanks for your opinion and experience
    TorqueRider Skellum 2 Replies Last reply
    • Giuseppe Marino Giuseppe Marino
      @Giuseppe-Marino
      Loading Routes Garmin Zumo XT (Click)
      Giuseppe Marino 1 Reply Last reply
      • TorqueRider TorqueRider
        @Giuseppe-Marino
        Giuseppe Marino
        Giuseppe Marino
        Giuseppe Marino
        @Jack-van-Tilburg many thanks for the link. I have looked and seen the difference between 1.1 and 1.2 and would like to ask a question. What is the difference between 1.0 and 1.1? If I load a route exported 1.1 onto the Zumo XT, when I open the route and touch GO the choices appear: STARTING WAYPOINT, CLOSEST POINT, ARRIVAL WAYPOINT, while if I export 1.0, in addition to the choices above, all the waypoints I have built also appear so I can choose where to start. This is useful when I start a route from a place that is far away from the start. What do you think of 1.0 ?
          @Giuseppe-Marino
          Most of the answers can be found in the Support section.
          Export instructions: general Garmin
            Skellum
            Skellum
            Skellum
            @Giuseppe-Marino - Steve Jarrett, a member of the MyRoute community posted some very helpful information on this subject late last year, I am sure he wouldn't mind me referring you to his post, as that could answer the issue you have regarding what export format to use. Hope it helps -Tony
            https://forum.myrouteapp.com/topic/2734/gpx-1-1-vs-1-2-simple-explanation
            Skellum
            Skellum
            Giuseppe Marino
            Giuseppe Marino
            • Stopover expiration time notification
