  4. 3.2.9.-154
3.2.9.-154
5 Posts 4 Posters 100 Views 1 Watching
  • Robert Laudensack
    Robert Laudensack
    Robert Laudensack
    Just tested it
    Problems:
    • The app still crashed several times when I tried to start the navigation, had to try it 4 times
    • the Navigation is laging a bit like 0.5s (in comparions to the MRA or Goggle maps)
    • on the route I did miss one exit, so I had to turn arround ... somehow it skiped the next point (I did not turn on the autoskip or manually skip) the whole detour was only 1 Minute/800m or so...
    • not 100% sure but in the beginning the voice guidance did not say anything dispite several tunr I had to take. As far as I remember it then started workin like after the 2nd way point- which was the 1st voice feedback I noted.
      Wishlist
    • as I have my mobile mounted rather flat it keeps on switching Portrait/Landscape in some turns. It would be good if one could lock the orientation to Portrait/Landscape just in navigation mode
      otherwise
    • many improovements I had waited for - love it!
    Robert Laudensack Corjan Meijerink 2 Replies Last reply
    • Robert Laudensack Robert Laudensack
      Just tested it
      Problems:
        Wishlist
        otherwise
      Robert Laudensack
      Robert Laudensack
      Robert Laudensack
      One other wish
      • please add a skip backwards or jump to point# which allows to skip go back ... I don't want to need to restart the navigation just because something went wrong ...
      Stefan Hummelink Ronni 2 Replies Last reply
        One other wish
        @Robert-Laudensack said in 3.2.9.-154:
        One other wish
        This is already implemented; simply longpress the previous waypoint or a next waypoint for that matter, and answer with yes. The nav will then recalculate from whatever the new starting point is. No matter the fact that the wp is past or upcoming.
          One other wish
          Ronni
          Ronni
          Ronni
          Hallo, try to longpress the waypoints. forward / backward
          Samsung Galaxy A56 5G
          Android 16
          One UI Vers. 8.0
          Carpuride W712D
          Silverfox BT Cntroller H1+
            Just tested it
            Problems:
              Wishlist
              otherwise
            @Robert-Laudensack Thanks for the feedback!
            • Crashes: working on it!
            • Lagging: continuously trying to improve it. Will fully be addressed when in final stage of development.
            • Voice guidance: will be more configurable / improved later!
            • Orientation lock: definitely will be added! Is also on our own wishlist 🙂
            • Previous waypoint: we might add a button to go to previous but for now you can indeed achieve it with a long press on any other waypoint 😉
            Great to hear you are happy with the other changes!
            Ronni
            Ronni
            Robert Laudensack
            Robert Laudensack
              Lluís Casals
              Lluís Casals
