  4. "Taschenrechner" while biking? Translation needed !
5 Posts 3 Posters 56 Views
  • Ronni
    Ronni
    Ronni
    I had never understood why I should use a calculator when riding a motorcycle. 🤔 (In German you need it to calculate more difficult mathematical functions 😊 ) So i opened that item in the toolkit menu of HERE. and discovered a great function. I can calculate the distance and time between 2 waypoints on my tour. Very good, I've always missed that.
    I would therefore rename the menu item because it sends you in the wrong direction
    Replace "Taschenrechner"--> with "Streckenberechnung".
    In addition, i would also adjust the following points:
    • In the sentence "Berechnen Sie die Entfernung und Zeit zwischen" I would drop the word "die" before "Entfernung". Sounds better in German, and
    • Replace "Zeit" --> with "Dauer".
    • The text in the button "Berechnung durchführen" should be left-aligned so that the text fits in one line. Or / And extend the background of the switch a little more to the right.
    • Drop "in Kilometer" from the white result block. That's already behind the numbers!
    • replace "Entfernung in Zeit" with "Dauer".
    • The English spelling of "0h 8m" should be replaced with "00:08 Std."
    • The separator at "43.60 km" in German is a comma "," and not a period "."'
    • In the PC version the grey "Entfernung" and "Dauer" fields are slightly up to fit in the white block.
    • In the app version, the white block overlays the switch label. However, if this is left-justified in a line, as described above, this problem is also solved.
    Because it's a lot of stuff in writing, I've roughly adapted it as a drawing. I hope this can be understood in a better way than my bumpy descriptions. (I just see, i forgot the icons in the white box )😖
    Greetings and Helau 💃 🕺 ✌ 🎸 🎤 🎭 🎆 🎇 🎹 💋 😌
    Ronni
    My Suggestion
    PC-Version
    App-Version
    Samsung Galaxy A56 5G
    Android 16
    One UI Vers. 8.0
    Carpuride W712D
    Silverfox BT Cntroller H1+
      Hi, thanks for all the suggestions for correct German. You just have to keep one thing in mind, in German everything is always much longer and gives the app makers a big headache to get everything on the screen. If possible, always suggest the shortest option. 👍
      We should get together and talk about the app, we only live a few kilometers apart.
      Ronni 1 Reply Last reply
        @Ronni Once again, thanks so much again for the improvements. I will definitely implement these in the coming week.
        @Jörgen said in "Taschenrechner" while biking? Translation needed !:
        Thanks for saying that, it can indeed be very annoying how a short word in English becomes a whole sentence in other languages 😉 This statement therefore is very true: shorter = better
        • Ronni Ronni
          Ronni
          My Suggestion
          PC-Version
          App-Version
          @Ronni I made sure most changes will be applied in the next website update. However, some changes are not possible.
          Those are not possible as the website does not support this 😞
          All textual improvements will be applied next week! 🎉
          Thanks for the feedback.
            Ronni
            Ronni
            Ronni
            Hi Jörgen, I'll have this in mind next time. 👍
            Hi, Jörgen, gerne. Ich schick Dir ne PN mit meiner Telefonnummer, dann können wir ein Treffen gerne absprechen.
            @Corjan-Meijerink said in "Taschenrechner" while biking? Translation needed !:
            Hi Corjan, I almost thought so. Perhaps it is possible just to replace the english "h" = hour with "Std." = Stunden?
            As fast as ever. 👍
            Greetings
            Ronni
            Android 16
            One UI Vers. 8.0
            Carpuride W712D
            Ronni
            Ronni
              Lluís Casals
              Lluís Casals
