  4. Gray squares on the here maps
3 Posts 2 Posters 37 Views
  • UltraStar
    UltraStar
    UltraStar
    This issue was reported many times already. When creating the routes on the Here maps, very often the gray squares show up on the map when zooming in and out. The parts of the map are out of focus at the same time. After a while the screen clears and the map is displayed nice and sharp. I have tested several different browsers with similar results. The network speed is very good. The issue displays itself faster or slower; I cannot find a pattern.
    This was not happening several months ago; I do not remember which version of the MRA was working correctly. This becomes real pain in the tush, lot of wasted time and aggravation.
    • UltraStar UltraStar
      @UltraStar Interesting, I’ll check the server load and see if something happened. Apologies for the inconvenience.
      UltraStar 1 Reply Last reply
        UltraStar
        UltraStar
        UltraStar
        @Corjan-Meijerink No worries; I know you will fix it eventually. It is just dragging for such a long time. Thank you for your attention.
        UltraStar
        UltraStar
          Lluís Casals
          Lluís Casals
