  3. Import POIs
Import POIs
6 Posts 3 Posters 1.4k Views 1 Watching
  • Gerd Heinzmann 0
    Gerd Heinzmann 0
    Gerd Heinzmann 0
    Is it possible to import POIs from Bascemp WITHOUT immediately calculating a route ?
    So as free-standing points?
    In Basecamp I have POIs
    When I import this GPX file as as POI file, I get a 'successful' message. but can't see the POIs.
    When I import this GPX file as a route, the POIs are automatically calculated as a route
    Thanks for any hints
    Kind regards
    gerry
    TorqueRider HABVEN aka MrMRA 2 Replies Last reply
    • Gerd Heinzmann 0 Gerd Heinzmann 0
      Kind regards
      gerry
      @Gerd-Heinzmann-0
      Use the upload option from the RouteLab and choose the <POI> tab in the next screen
      Then you will find your POIs in the left column when creating a route.
      Manual POI's Click
        Kind regards
        gerry
        @Gerd-Heinzmann-0
        Hello Gerry,
        Save this file as .csv (POI) or .ov2 (POI) and then upload is as POI file.
        Open a route, go to Points of Interest in the left menu and tick on the Library tab, then thick on the checkbox wich poi's you want to make visible on the map (zoom)
        Gerd Heinzmann 0 1 Reply Last reply
          @Gerd-Heinzmann-0
          Hello Gerry,
          Gerd Heinzmann 0
          Gerd Heinzmann 0
          Gerd Heinzmann 0
          Thanks for you answers.
          Unfortunately it doesn't work up to now.
          @Hans-van-de-Ven-MRA-Master
          When I open your file, I can see all your POIs on the map and on the left side of the panel
          I saved this file and imported it to my route.
          Now it looks like this
          The group of POs seem to be there, but I cannot see any of the Points
          What am I doing wrong ?
          Thanks, regards
          gerry
            Thanks, regards
            gerry
            @Gerd-Heinzmann-0
            Did you upload the file as poi?
            Open a route, tick on the checkbox in thee poi library and zoom in on the map
              @Gerd-Heinzmann-0
              Gerd Heinzmann 0
              Gerd Heinzmann 0
              Gerd Heinzmann 0
              Aah... I was to hasty.
              I didn't zoom in enough !
              Thanks a lot
              Gerd Heinzmann 0
              Gerd Heinzmann 0
                TomOnTour
                TomOnTour
              • Newsletter optimisation
              • Trekking tool: sun/shade
                Kudee
                Kudee
                TomOnTour
                TomOnTour
