  4. Suggestion: GPS measured speed - gray out on no GPS signal
suggestionnextgps signalspeed
6 Posts 5 Posters 72 Views 1 Watching
  • Hans Hüppi
    Hans Hüppi
    Hans Hüppi
    I am using quit often the GPS measured speed as orientation for my real driving speed. If I drive too fast, then the background turns red. Perfect so far.
    Since I am living and riding mainly in Switzerland I pas quite a bit of tunnels on normal roads and highways. Of course, there is no measured GPS speed in tunnels, but in the display, it shows continuously the last measured GPS speed. This is misleading.
    Wish/suggestion: If the GPS signal is not received anymore, I suggest striking trough the speed (from top left to right bottom in the square) since it's not the actual speed anymore until a valid GPS signal is received again.
    Drabslab michaelknight 2 Replies Last reply
    • Hans Hüppi Hans Hüppi
      Drabslab
      Drabslab
      Drabslab
      @Hans-Hüppi +1
        michaelknight
        michaelknight
        michaelknight
        @Hans-Hüppi +1
        • michaelknight michaelknight
          @Hans-Hüppi +1
          @Mike-Knight said in Suggestion: GPS measured speed - gray out on no GPS signal:
          @Hans-Hüppi +1
          @Drabslab said in Suggestion: GPS measured speed - gray out on no GPS signal:
          @Hans-Hüppi +1
          Off topic: Instead of the comment +1 you can use this button (see picture). That keeps the topic readable and clear!
            @Hans-Hüppi +1
            @Hans-Hüppi +1
            @Rob-Verhoeff , +1! (just joking 😉 )
              @Con-Hennekens said in Suggestion: GPS measured speed - gray out on no GPS signal:
              Drabslab
              Drabslab
              Hans Hüppi
              Hans Hüppi
              michaelknight
              michaelknight
                Axel Lange
                Axel Lange
              • In het kort......
              • Route probleem
                Jack 13
                Jack 13
