  3. Highlight blocked roads (e.g. in the way point list)
4 Posts 2 Posters 762 Views 1 Watching
  • FrankS
    FrankS
    FrankS
    Hello everyone,
    I have another feature request: if a planned route uses a road that is shown as blocked when you enable "traffic" in the maps menu, e.g. because of construction work, it would be great if the affected road block or connection between two waypoints would be highlighted so that I can change my route planning to avoid this road block.
    Right now, I see this block not before I export to and load the route on my GPS (TomTom 550).
    Thank you
    Freddy
    • FrankS FrankS
      Hello everyone,
      Thank you
      Freddy
      @Freddy-Schenk
      Hello Freddy,
      Hi Freddy,
      That depends on what the road authorities pass on to the map suppliers. I always use the combination of the traffic layer and TomTom Mydrive, because that also contains a lot of information.
      And, as Stefan indicates, you can check this in Google My Maps. Click!
      FrankS 1 Reply Last reply
        @Freddy-Schenk
        Hello Freddy,
        Hi Freddy,
        FrankS
        FrankS
        FrankS
        @Hans-van-de-Ven-MRA-Master
        Hi Hans,
        if the road is displayed as blocked (with black lines on both sides of the road), then this is not a matter of IF this has been reported, because it obviously HAS been reported.
        My point is that the routing should circumvent / avoid this section.
        Thank you
        Freddy
        PS: By the way: in another comment I suggested that the black lines on both sides on the blocked road should be replaced by another, well visible pattern, e.g. bold red-white, so that I can see them immediately when I plan a route. Currently, the the black lines that indicate a road block are not visible since my planned route is also black. Usability matters 🙂
        • FrankS FrankS
          Hi Hans,
          Thank you
          Freddy
          FrankS
          FrankS
          FrankS
          wrote on last edited by FrankS
          @Freddy-Schenk
          Example for both problems, coloring and routing:
          Detailed view, see the black lines above, on and below the section:
          Normal planning view, which I normally use (no, I do not drive the complete route virtually before I drive it on the bike :-))
          Regarding routing: if I change the map from TomTom to OpenStreetMap, the deviation works:
          FrankS
          FrankS
          • Hello everyone
          • Route changed?
          • Hoe lang moet je abo hebbes voor toegang??
          • Beurs aanbieding
          • Wissel Here-TomTom
          • Hoe lang gebruiker
          • Hello from Thailand
