  3. Come far evitare o inserire il percorso in autostrada.
7 Posts 4 Posters 1.2k Views 1 Watching
  • Massimo Campanardi
    Massimo Campanardi
    Massimo Campanardi
    • Massimo Campanardi Massimo Campanardi
      @massimo-campanardi said in Come far evitare o inserire il percorso in autostrada.:
      More information would help people answer your question. With a gold account you have the option to avoid highways, toll roads, ferry etcetera.
      Massimo Campanardi 1 Reply Last reply
        Massimo Campanardi
        Massimo Campanardi
        Massimo Campanardi
        @nick-carthew said in Come far evitare o inserire il percorso in autostrada.:
        Thank you. I see to explain: by drawing a route, I would like MRA to allow me to decide whether or not to use the motorway and in the same route to be able to decide to make a section with the motorway and other sections without. I can't figure out how, where to click, etc. Thanks for your help!
          @massimo-campanardi
          Only if you use the OSM, Open Street Map, map for planning
            @massimo-campanardi
            Massimo Campanardi
            Massimo Campanardi
            Massimo Campanardi
            @hans-van-de-ven-mra-master
            Thanks .... So I who use the standard Google map cannot take advantage of this. Pity.....
              @massimo-campanardi Google Maps is only an overlay, not a map used for calculating the route. If you select OpenStreetMap as the Map (used for calculation), you can still use the Google Maps overlay.
                Massimo Campanardi
                Massimo Campanardi
                Massimo Campanardi
                @herko-ter-horst said in Come far evitare o inserire il percorso in autostrada.:
                Thanks - I get it.
                Massimo Campanardi
                Massimo Campanardi
                  martin-phogel.de
                  martin-phogel.de
                  12.0k
                • F004 MRA Navigation Error
                • Probleem met eigen Stay
                  Albert van den Elsen
                • Reclame van Navigation Next blokkeert de navigatie.
