  3. Import Gpx from kurviger, adjust route - then navigate with MRA
6 Posts 3 Posters 1.5k Views 2 Watching
  • Bauke Keulen
    Bauke Keulen
    Bauke Keulen
    wrote on last edited by Bauke Keulen
    My brother and I are travelling Portugal (ACT route). He uses Kurviger… I’m importing it in MRA and checking the route for problems. When all is okay, we’re navigating with MRA on my iPhone. So far so good. It’s a standard route, no extra curves, avoiding highways in settings or anything.
    Unfortunately I’m experiencing some strange errors in the route (see pics). Why is this happening? The route seems perfect in placements of all waypoints. Please help. In the meanwhile we’re using OsmAnd with the same route from Kurviger and no problems with that.
    We made a fun movie 🙂 https://youtu.be/6eh6yH4zNus
    C3B0FBDA-CAAE-4C16-BCA1-0EB4A1CF5857.jpeg D615C185-FC6A-453C-8082-C662743FE182.jpeg B3BD1BA5-262A-4C3C-8CE7-6412E13241F0.jpeg
    • Bouke Ent
      there is a differance between osm and here data. always when gold member use option in toolkit to compare route and put marker on route. if not you get a lot of this.
      my situation is rider and mra navigation so i have to check always if markers are spot on the route.
      Bauke Keulen 1 Reply Last reply
      • Bauke Keulen Bauke Keulen
        @bauke-keulen Het beste kan je een link naar jouw route hier delen. Dan kunnen we de route bekijken? Hoogstwaarschijnlijk is de route niet goed in de Here kaart omdat deze initieel in OSM gemaakt is. Voor correct gebruik van MRA Nav moet je altijd in Here de route controleren.
        • Bouke Ent Bouke Ent
          Bauke Keulen
          Bauke Keulen
          Bauke Keulen
          @bouke-ent I checked the comparison. And indeed there are some corrections to be made. For the next route (Cedeira - Astorga) we’ll try again 🙂 Thanks for your help.
            Bauke Keulen
            Bauke Keulen
            Bauke Keulen
            @stefanhummelink said in Import Gpx from kurviger, adjust route - then navigate with MRA:
            Je had gelijk, dit heb ik over ‘t hoofd gezien. Ik heb een gold abonnement dus had het kunnen weten. Wel een gedoe om die punten elke keer langs te lopen en te shuffelen met waypoints.
              @bauke-keulen said in Import Gpx from kurviger, adjust route - then navigate with MRA:
              Dat is helaas collateral damage bij het gebruiken van meerdere navigatie systemen en daarmee dus ook verschillende kaart data :).
              Bauke Keulen
              Bauke Keulen
                TomOnTour
                TomOnTour
              • Android Auto TFT
              • Notche
                Adriaan Vonk
                Adriaan Vonk
              • Select friends problem
                stuart marritt
                stuart marritt
