  3. Feature suggestion - Option to show routes in folder in an overview
2 Posts 2 Posters 475 Views
  • Gert-Jan Hiddink Offline
    Gert-Jan Hiddink
    MRA is perfect for creating routes, really like it. When I'm planning for a biketrip, I create a folder for this. I like to keep things organised.
    Usually I first make the overview and select a number of highlights. After that I create a route per day. The overview though, still has value to me. So I try to keep that 'up-2-date'.
    But it gets painful to keep the routes per day 'in sync' with the overview. I know one can open a route, and then 'add' other routes with different colors. Nice feature, but is not what I mean, because I always need to start 'editing' a route and then add the other routes.
    Also, keeping the overview up-2-date get's more painful with a longer trip. Because of the calculation that needs to be done when changing the route a bit.
    What I would appreciate is the ability to select a couple of routes (all?) in a map, and then have the ability to show them 'read-only' in an overview. Now I can select routes, and then copy/move/delete them. A new button there to generate the overview, would be great!!!
    The card material used for calculating the routes, should be the chosen default of the user.
    Nice to have:
    • alternating colors for each route
    • ability to choose coloring
    • when hovering over a route in the overview a text showing the source route
    • total length
    • export to csv: name, start-name, start-address, end-name, end-address, length, duration
    • Gert-Jan Hiddink Gert-Jan Hiddink
      Nice to have:
      • total length
      Nick Carthew Offline
      @gert-jan-hiddink The developers are currently working hard at getting some updates done, see Michel’s blog READ BLOG
      I have asked if an overview of all routes in a folder is possible and could we have it in a future update. The answer was: This should be possible although they need to finish the current list of updates.
      Gert-Jan Hiddink
      Gert-Jan Hiddink
      • Interesting behaviour on a pre-planned route that uses the same road in both directions
      • Onbegrijpelijke afslagen
      • Stemgeluid sterker bij afspelen muziek
      • GPX1.2 & Garmin Tread
        MTC-Zeilberg
        MTC-Zeilberg
        Huibertus
        Huibertus
      • Update 5.2.1 - Android availability
        TomOnTour
        TomOnTour
