  3. Stops on the way
Stops on the way
10 Posts 8 Posters 2.4k Views 2 Watching
  • Karsten Lund 0
    Karsten Lund 0
    Karsten Lund 0
    Hi fellas
    If I am driving along a route that I have made and take a break and turn the satnav off (Garmin 590) will it pop back on the route when I start it up again?
    Best regards
    Karsten
    Tino Wintershoven HABVEN aka MrMRA Drabslab Reinhard-32 5 Replies Last reply
    • Karsten Lund 0 Karsten Lund 0
      Hi fellas
      Best regards
      Karsten
      Tino Wintershoven
      Tino Wintershoven
      Tino Wintershoven
      @Karsten-Lund-0
      First of all. This has nothing to do with MRA but i will answer you anyway.
      Yes. Your nav will popup back with the route on your display.
      Regards.
      Karsten Lund 0 1 Reply Last reply
        Hi fellas
        Best regards
        Karsten
        @Karsten-Lund-0
        You just have to push the on/off button once
        • Tino Wintershoven Tino Wintershoven
          @Karsten-Lund-0
          Regards.
          Karsten Lund 0
          Karsten Lund 0
          Karsten Lund 0
          @Tino-Wintershoven If I am using a route created in MRA, yes it has a lot to do with MRA but thanks
            Hi fellas
            Best regards
            Karsten
            Drabslab
            Drabslab
            Drabslab
            @Karsten-Lund-0 Hello Karsten,
            The MRA routeplanner delivers a route in a format you select, usually (and for garmin) this will be the GPX 1.1 format.
            This format is a standard that can be read by many different GPS devices made by different manufacturers. Unfortunately, each one of these devices has its own "perks".
            Some GPS you can "put to sleep" in which case turning them back on will make them continue the route. Others you can only "shutt down" making them loose all memory of on-going routes.
            I have no clue if the Garmin 590 makes a distinction between being sleeping or shutt down but that you should find in the manual.
            I hope this helps 🙂
            jonny0000 1 Reply Last reply
            • Alexa Smith
              Alexa Smith
              Alexa Smith
              Thank you so much Drabslab. Your detailed reply helped me a lot.
              • Drabslab Drabslab
                I hope this helps 🙂
                jonny0000
                jonny0000
                jonny0000
                @Drabslab Thank you for detailed reply.
                  Hi fellas
                  Best regards
                  Karsten
                  Reinhard-32
                  Reinhard-32
                  Reinhard-32
                  This post is deleted!
                    Hi fellas
                    Best regards
                    Karsten
                    Reinhard-32
                    Reinhard-32
                    Reinhard-32
                    @Karsten-Lund-0
                    I have a Garmin Zumo 590 and a ZumoXT and can confirm that the route will continue after wake up from sleep mode.. When you remove the 590 from the cradle without any action it falls in the sleep mode automatically or if you press the On/Off button shortly als well.
                    • WhatAPK
                      WhatAPK
                      WhatAPK
                      wrote on last edited by WhatAPK
                      Drabslab
                      Drabslab
                      Reinhard-32
                      Reinhard-32
                      Tino Wintershoven
                      Tino Wintershoven
                      Karsten Lund 0
                      Karsten Lund 0
                      WhatAPK
                      WhatAPK
                      jonny0000
                      jonny0000
                      Alexa Smith
                      Alexa Smith
                      • Kaart niet zichtbaar
                      • Xpert overlay not clear
                      • Google maps
                        Ed Bos 0
                        Ed Bos 0
                        Jaap van Maanen
                        Jaap van Maanen
                        Corrado Miniati 0
                        Corrado Miniati 0
