  3. Rename routes
Rename routes
13 Posts 5 Posters 2.6k Views 3 Watching
  • Dolomiti
    Dolomiti
    Dolomiti
    My routes where imported automatically in Navigation app, however when I renamed the routes afterwards in the routeplanner app on the PC, the routes in the Navigation app still show the original names and are not updated or synchronized. How to correct this to show the updated names of the route in the Navigation app as well?
    Thanks.
    Stefan Hummelink HABVEN aka MrMRA 3 Replies Last reply
    • Dolomiti Dolomiti
      Thanks.
      @dolomiti should be reflected automatically. You can swipe down on the route list to refresh.
      Dolomiti 1 Reply Last reply
        Dolomiti
        Dolomiti
        Dolomiti
        @stefanhummelink Doesn't refresh even if I swipe down. Trying in on iOS phone.
        • Dolomiti Dolomiti
          @dolomiti On my android phone the list is being refreshed when swiping down. Don't know the iOS behaviour.
            Dolomiti
            Dolomiti
            Dolomiti
            @stefanhummelink Thanks for the advice, unfortunately it isn't working for me for one or the other reason. I just installed the app on my Android tablet and same result. The name of the route remains the same after I change it. Adding and deleting is synchronized automatically immediately, but not the renaming. Very strange.
            • Dolomiti Dolomiti
              @dolomiti Oh wow, after seeing your findings I tried it as well but now I tried to rename the route myself too and indeed route name changes are not synced, but only after editing the route slightly, i.e. moving a waypoint a bit. That's a hassle. Damn. I really thought the refresh shoud have synced the route name as well.
              I'm sorry!
                I'm sorry!
                Dolomiti
                Dolomiti
                Dolomiti
                @stefanhummelink Thanks, this tip was helpful. Actually make a vormingspunt a viapunt and back again is already enough to do the trick. Hopefully they will fix this bug soon.
                Stefan Hummelink Steve Lynch 2 Replies Last reply
                • Dolomiti Dolomiti
                  @dolomiti Indeed, that kind of "modification" does the same thing. πŸ˜ƒ
                  • Dolomiti Dolomiti
                    Steve Lynch
                    Steve Lynch
                    Steve Lynch
                    @dolomiti
                    Not sure this is considered a bug as this was a request some time ago to stop the the date from changing even if you opened a route and no changes were made at all.
                    At least you have the workaround now.
                    Below is the link to the thread that instigated the change.
                    https://forum.myrouteapp.com/topic/1751/bug-report-mra-web-last-modified-date-changes-when-no-changes-were-made
                    • Steve Lynch Steve Lynch
                      @dolomiti
                      @steve-lynch That bug was about the order of routes (sorted by date) in the navigation app being unduly affected by just viewing a route. A route rename not syncing (i.e. not being visible in the navigation app at all on its own) is a completely separate issue in my opinion.
                      It might have been caused by work done to fix the 'modification date' bug, but I would still consider a rename not being visible in the app to be unexpected and unwanted behavior, i.e. a bug.
                      • Dolomiti Dolomiti
                        Thanks.
                        @dolomiti
                        Hi all, Has been reported to the developers.
                          @dolomiti
                          Dolomiti
                          Dolomiti
                          Dolomiti
                          @hans-van-de-ven-mra-master Great, thank you!
                          • Dolomiti Dolomiti
                            Thanks.
                            @dolomiti
                            Hi all, problem is fixed by the developers
                            Steve Lynch
                            Steve Lynch
                            Dolomiti
                            Dolomiti
                              11.9k
                            • F004 MRA Navigation Error
                            • Probleem met eigen Stay
                              Albert van den Elsen
                            • POI functie 'strict'
