  3. Can't move waypoints. (Windows 10)
10 Posts 6 Posters 1.7k Views 1 Watching
  • Martin P Williams
    Martin P Williams
    Martin P Williams
    Anyone else having issues moving waypoints? The loading wheel just spins and nothing happens.
    Thanks
    • HABVEN aka MrMRA
      Hello @Martin-P-Williams
      Yes same problem here, I informed the MRA Team.
      Thans for sharing.
      • Martin P Williams
        Martin P Williams
        Martin P Williams
        Same problem on Google Chrome & Microsoft Edge.
        Can anyone check if they can move waypoints please?
        • Handscombmp
          Handscombmp
          Handscombmp
          I've got the same issue as well. Also get it if i try to added waypoints.
          I've also tried to load a route from the EXpert Library and get a database error
          A Database Error Occurred
          Error Number:
          ERROR: WKB structure does not match expected size!
          SELECT *, ST_AsGeoJSON(polygon) as geojson FROM "countries"."regions" WHERE "id" = '104' LIMIT 1
          Filename: /app/models/geometry_model.php
          Line Number: 296
          • HABVEN aka MrMRA
            Hi all,
            The MRA Team is working on it, the RouteXpert library is currently being worked on.
            Martin P Williams 1 Reply Last reply
              Hi all,
              Martin P Williams
              Martin P Williams
              Martin P Williams
              @Hans-van-de-Ven-MRA-Master said in Can't move waypoints. (Windows 10):
              Hi all,
              Thanks for the update Hans.
              • Tony Cox 0 0
                Tony Cox 0 0
                Tony Cox 0 0
                I can’t even enter a waypoint at moment. The wheel just keeps turning! I had previously responded to a message to update the app. I think this has caused the problem. Anyone else having the same issue!
                • Martin P Williams
                  Martin P Williams
                  Martin P Williams
                  I can add Waypoints no problem, it's just moving an existing waypoint that doesn't work for me.
                    Issue has been resolved!
                      @Corjan-Meijerink 🥷
                      Handscombmp
                      Handscombmp
                      Martin P Williams
                      Martin P Williams
                      Tony Cox 0 0
                      Tony Cox 0 0
                        martin-phogel.de
                        martin-phogel.de
                        12.0k
                      • F004 MRA Navigation Error
                      • Probleem met eigen Stay
                        Albert van den Elsen
                      • POI functie 'strict'
