  2. Routes & Tracks
  3. How can I add a coffee stop in my route?
4 Posts 4 Posters 1.6k Views 1 Watching
  • Leslie Barnes
    Leslie Barnes
    Leslie Barnes
    How can I add a coffee stop in my route? in the route HERE add poi coffee see it on the PC but when riding dont see anything?
    • AndreBC
      AndreBC
      AndreBC
      When you found a spot to make your stop then add a waypoint. After making the waypoint you click on that waypoint, there you can find ADD PAUSE. Via the dropdown menu you can choice how long you want to take a break
      • Leslie Barnes Leslie Barnes
        @Leslie-Barnes It depends on your device. Which navigation device are you using?
        • PAD 0
          PAD 0
          PAD 0
          Regardless of the program/app used, I avoid adding POIs to my routes as, over the years, I have found they can provide unreliable data. Petrol stations no longer in existence, cafés closed down, etc. I do use POIs in the planning stage, but only as an indicator of what might exist in an area. Based on them, I double check using other sources, such as Google Maps & Street View (always checking the date of the Street View imaging because it can vary widely) and following website links to a venue, etc.
          Once I’m satisfied that a venue or location checks out, I add it as a waypoint, label it appropriately and set it as a via point, rather than a shaping point.
          That might seem a bit OTT to some? But I plan a number of tours, group and long rides each year and I have found that this approach can save a lot of hassle on the road.
          Leslie Barnes
          Leslie Barnes
          AndreBC
          AndreBC
          PAD 0
          PAD 0
            Vincible
            Vincible
