  3. Round-trip generator (rondrit generator) doesn't work from some points
13 Posts 3 Posters 2.4k Views 1 Watching
  • sudolea
    sudolea
    sudolea
    Hello,
    I've noticed, while trying out the "rondrit generator" (can I translate this into "roundtrip generator" ?) doesn't seem to work from most starting points that I select in some small village. More specifically, I'm trying to make some roundtrips starting in Krewinkel, a small village in the Belgian Eastern Cantons. I wonder why that can be ?
    Whether I'm selecting my starting point on the road itself, or on crossroads, it all doesn't seem to make a big difference. On the other hand, selecting some bigger village in the neighbourhood doesn't seem to have those problems.
    Is there a logic that I could follow to prevent such difficulties, rather than to try-and-fail ?
    HABVEN aka MrMRA 2 Replies Last reply
    • TorqueRider
      I have also tried to generate a roundtour from Krewinkel. It doesn't work with me either.
      Tried in different directions and different distances.
      See picture:
      sudolea 1 Reply Last reply
      • TorqueRider TorqueRider
        See picture:
        sudolea
        sudolea
        sudolea
        @Jack-van-Tilburg Thank you for trying it out too. I had been wondering if the problem was at my side, so I had thought to mention Krewinkel hoping that someone would try it out too, so thanks for verifying this.
        Is this a bug, or some "faulty usage" of the feature, I ask myself ... I tend to think in the direction of some bug ...
        • TorqueRider
          You can apparently select/use every avoidance except "Cities".
          When you deselect "Cities" your route will be generated.
          • sudolea sudolea
            Hello,
            @sudolea
            Did you try the “surprise me “ option from the same location?
            • TorqueRider
              @sudolea said in Round-trip generator (rondrit generator) doesn't work from some points:
              Krewinkel
              Same result but an slightly other notification 🙂
              • sudolea
                sudolea
                sudolea
                Yes, Hans, I did :
                • sudolea sudolea
                  Hello,
                  @sudolea
                  What distance did you add?
                  TorqueRider sudolea 2 Replies Last reply
                  • sudolea sudolea
                    Yes, Hans, I did :
                    @sudolea
                    I will inform the developmet team, thanks fot sharing.
                      @sudolea
                      @Hans-van-de-Ven-MRA-Master
                      100, 150 en 200 km.
                        @sudolea
                        sudolea
                        sudolea
                        sudolea
                        @Hans-van-de-Ven-MRA-Master I tried 250 km, and gradually decreased the distance, also entered a duration when distances didn't work. I most frequently set the direction towards the Eifel, Luxemburg, or Germany.
                          @sudolea
                          sudolea
                          sudolea
                          sudolea
                          @Hans-van-de-Ven-MRA-Master OK, top, thank you.
                          For what it's worth : the solution Jack suggests works indeed. However, I think it's suboptimal : I would rather suggest an immediate and intuitive error message when starting a roundtrip from a point of which the software knows that it will result into an "impossible" route. This saves the user from executing the 4 following steps to only at the end be (frustratingly) notified that "there could be found no route". It would also enable a user to let the option to "avoid cities" remain active and select another point right at the start of a roundtrip setup...
                            100, 150 en 200 km.
                            @Jack-van-Tilburg
                            It didn't work for me, I did a test yesterday
                            sudolea
                            sudolea
                            • Kaart niet zichtbaar
                            • Xpert overlay not clear
                              Corrado Miniati 0
                              Corrado Miniati 0
                            • Google maps
                              Ed Bos 0
                              Ed Bos 0
                            • Trains like Ferries?
                              Corrado Miniati 0
                              Corrado Miniati 0
