  2. Export assistance
  3. [Export] Garmin
  4. How to export GPX files to Zumo XT without recalculation
51 Posts 16 Posters 4.1k Views 4 Watching
  • BertM BertM
    @Stevedo-6-0 said:
    , I suggest zumoforums.co.uk.
    better look for https://zumouserforums.co.uk/ šŸ˜‰
    @BertM Apologies, you are correct. Looks like I can no longer edit my error šŸ˜ž
    BertM 1 Reply Last reply
    • Stevedo 6 0 Stevedo 6 0
      No Apologies needed, just wanted to point out to the right forum.
      • Andy Beviere
        Andy Beviere
        Andy Beviere
        I just understand how people can say they have zero problems with Garmins when all the guys I ride with have binned them and these aren’t stupid people… they’re quite tech savvyā€¦šŸ¤·ā€ā™‚ļø
          @Andy-Beviere
          PS You are free to think whatever you like.
          I have also never encountered any issues with the routes I create and send to a Garmin Zumo 660, 395, 590, XT, XT2, XT3, TomTom, or BMW CRN. That said, the fact remains that a route still has to be calculated.
          I did have issues when using a Carpe Iter tablet—which, incidentally, didn't stay on my motorcycle for very long. I’m not familiar with DMD; after my experience with the Carpe Iter, I’ve come to the conclusion that a dedicated navigation device works best—after all, that’s what they’re designed for. A tablet or smartphone is, at best, just a makeshift solution.
          Andy Beviere
          Andy Beviere
          Andy Beviere
          @HABVEN-aka-MrMRA That’s why I use a dedicated sat nav…? šŸ‘ŒšŸ‘
          • John S Parry
            These topics bashing the Garmin XT series devices will never stop. The units take some dedicated effort to understand, and frankly most riders don’t want to put in the effort. If it doesn’t work like Google right out of the box, there must be something wrong with it. In a world of simple phone app alternatives the motivation simply isn’t there to dig in. And that’s OK because phone apps are all that most riders need,
            Regardless, MRA Routeplanner is the best available routing SW on the market. Garmin GPS devices have the most total core capabilities of any navigation options on the market. If you truly know how to use each, they 100% work well together. It’s not debatable.
            I wish more who come on here would approach this from the standpoint of ā€œwhat am I doing wrong?ā€. It would be a much more productive exchange.
            Andy Beviere 1 Reply Last reply
            • Mzokk
              Even those of us who have used Garmin devices for years and understand the associated software (up to the Garmin XT1) Will bash Garmin for good reason.
              Good
              The Hardware.....robust water dust and heat proof. My Oldest Garmin device is 22 and still works.
              The Desktop software Mapsource and later Basecamp are fine pieces of software and I still use Basecamp for handling tracks and POI's as this is an area in MRA that still needs work.
              Bad
              The XT1 and I believe the 2 and 3 have a bug with "imported" routes which causes repeated U turns if a via point is missed (even if skipped). This can be mitigated by making all routes "Saved" but its something to be aware of.
              Somewhere after the Zumo 390 and 590 GPS units Garmin changed the Routing algorithm of the devices so that with the devices set using the same parameters "Faster Time" no longer meant the fastest time between two way points irrespective of road type but meant "Faster Roads" creating additional complication when designing routes for a Garmin XT1 for example as Basecamp routes were not longer WYSIWYG with the GPS unit.
              For the XT1 "explore" does not add value to the experience of using the unit if you connect it. Its a poor piece of software IMO. In many ways MRA is what explore should have been.
              Garmin's recent software has in general been buggy. The otherwise excellent "Drive" app was broken for Android users recently when they added functionality unrelated to the Zumo XT
              If you are using the unit outside its area for example using a Europe unit in the US or visa versa you can load Garmin's expensive "Here" maps or you have to Garminise Open Street Maps to get coverage.
              I've moved to navigation using the MRA navigation app. Mainly because my Africa twin has built in AA/CP and I can manipulate the software using my bar buttons which is safer and more convenient than prodding the XT screen (I now I should stop!)
              What I have found is that working this way via android auto is more flexible. I use My Route app navigation for routes. OSMand for tracks and Google maps for fast A-B navigation and using voice commands to find coffee and lunch stops. I still have my XT mounted as a backup with my routes and tracks "Saved" on it. I have the Track displayed on it and any Custom or proximity alerted POI's I might want to use loaded.
              • Travellexxie Travellexxie
                @HABVEN-aka-MrMRA not 50 viapoints? šŸ¤£šŸ™ˆ
                Olivier Weinand
                Olivier Weinand
                Olivier Weinand
                @Travellexxie 50 points is not applied to XT!
                Garmin zūmo XT (Original) Limits
                • Via Points Limit: 29 intermediate via points max (31 total via points including Start and End). Going over this forces an automatic route split.
                • Shaping Points Limit: Up to 125 unannounced shaping points allowed between each via point.
                • Total Combined Capacity: Because of the 125-shaping-point gap allowance between each of the 31 total via points, a single intact route file can mathematically hold up to ~3,750 points total, successfully ignoring the confusing "50-point cap" written in some of Garmin's general documentation.
                BUT
                DO NOT use a total if too many points in total as this slows down the XTā€˜s calculation.
                Garmin zūmo XT2 & XT3 Limits
                The newer generations completely dropped the restriction of a "points between vias" architecture in favor of a massive flat pool:
                • Via Points Limit: A flat maximum of 100 via points total per route.
                • Shaping Points Limit: A flat maximum of 1,000 shaping points total per route.
                • Total Combined Capacity: The routing engine allows up to 1,100 total combined routing points on a single calculated trip.
                Why did Garmin reduce the total capacity of points from XT to XT 2 and XT3?
                While it looks like a downgrade on paper, Garmin changed this to fix a massive performance flaw.
                On the original zūmo XT, if you actually tried to load a complex route containing thousands of points, the device's processor would choke. It would take several minutes to calculate, lag heavily when you went off-route, or completely crash mid-ride. The "125 points between vias" rule was a legacy structural setting in Garmin's code, but the hardware couldn't smoothly run a single route packed to that limit.
                By switching the XT2 and XT3 to a strict 1,100 total point ceiling, Garmin ensured the routing engine always has enough computational headroom to calculate instantly, render complex maps smoothly, and recalculate on the fly without lagging.
                • Olivier Weinand Olivier Weinand
                  BUT
                  @Olivier-Weinand you missed the smileys?! I know the features of the XT, it was a joke between @habven-aka-mrmra and me.
                  • Guzt
                    Guzt
                    Guzt
                    I use the HERE map set with vehicle on car. All stops are waypoints. I optimize my routes using the toolkit switching from faster time to shorter distance and drag the route to either the reference route or the track. Once done, I export the route gpx 1.1 (route, track, poi) and either import it using the Drive app or put it directly in the gpx folder in the XT. Recalculation is always set on yes. The route will be for 99.9% correct. The track is always set to visible as reference.
                    • Guzt Guzt
                      @Guzt Are you still able to export using the Garmin Drive app? There are many reports that it is not working again after another update from Garmin.
                      • Guzt
                        Guzt
                        Guzt
                        @nick-carthew I didn't update the Drive app. Still running v4.23.32 on my old SE10 iPhone
                        • Guzt Guzt
                          @Guzt I think that was a wise move. Thanks for your reply.
                          • Guzt
                            Guzt
                            Guzt
                            @nick-carthew iOS of my old SE10 mini is 15.8.8. Drive app requires 16.5 or later. But one can still install it using an old version of iTunes where the apps tab is still available
                              @Travellexxie šŸ˜… šŸ˜„
                              • Travellexxie
                                Problems with the Drive-app are, what I read, only with iOS. I updated my phone and tablet, both on Android, and they work fine.
                                • Mzokk Mzokk
                                  Good
                                  Bad
                                  wrote last edited by John S Parry
                                  #36
                                  @mzokk I didn't mean for my post to generate a critique for what's right/wrong with the XT. All navigation HW/SW has bugs, oddities or whatever you want to call them . The Garmin XT series is not immune. My main point is that if you know how the XTs (XT, XT2, XT3) work -- REALLY WORK, they're a perfectly good GPS solution. A properly constructed route in MRA or any other planner will execute correctly. The XTs don't screw up routes unless you've done something seriously wrong. Yet we get a parade of users who trash the units when it's instead operator error. Self-reflection is a much better solution in this realm.
                                  As far as your comments, with due respect, RUT is not a universal problem. I've been using Garmins (BMW Nav VI, Zumo XT, XT3) as my primary route execution devices over the past 8 years, and I've never experienced RUT. I know that it exists, but hitting it depends on how you execute off-route recalculations. I've personally always subscribed to what's outlined in post #30 of this excellent MRA forum topic, which you also contributed to:
                                  https://forum.myrouteapp.com/topic/11124/gpx-versions-1.1-vs-1.2-for-garmin-visually-explained/21?page=2
                                  In short, I never turn auto recalculate on. I create routes to be ridden as created. I almost never deviate enough to need recalculations to continue back on-route. If I do, I have other approaches/tools to get back on track. The beauty of Garmins is that the route continues when you rejoin at a later point without having to recalculate anything. To me, this is one of the advantages of using an XT device for navigation.
                                  Your other "Bad" items don't register on my radar. The Tread app for the XT2/XT3 is excellent IF you configure it carefully/correctly when installed. Most users get in trouble because they install without understanding the pros/cons of the options available.
                                  I'm all for having debates and/or conversations when the people making complains understand the XT GPS units. Unfortunately, most of the time they don't.
                                    @Andy-Beviere
                                    Andy Beviere
                                    Andy Beviere
                                    Andy Beviere
                                    @HABVEN-aka-MrMRA can you explain how you do it then please… I purchased a new bike at the weekend borrowed a mates XT2 for the bmw mount as I didn’t have time to put the DMD tablet on whilst he went with his DMD device, first roundabout we got to, we went left, next thing we know we’re getting the dreaded off route notification on the Garmin… !!! Literally half a flipping mile from the house.
                                    • John S Parry John S Parry
                                      Andy Beviere
                                      Andy Beviere
                                      Andy Beviere
                                      wrote last edited by Andy Beviere
                                      #38
                                      @John-S-Parry interesting John, so why are we on a forum if its not debatable???šŸ˜‚
                                      I’ve wasted hours trying to get most BMW nav’s and the XT range to follow routes and I fail and the annoying thing is I’ve no idea why, I have tried everything, was a little better with the XT and the drive app…. please don’t assume that people don't like to work a problem because I do…and in the end I gave up and went to another brand which simply follows the route you put on it.
                                      Therefore if you have the time and you’re willing, can you please reply with exactly what you do from planning to exporting to using the device and I will attempt to replicate your guidance on Friday when we all go for a ride… don’t need war and peace just bullet points will do e.g file type, transfer wired or WiFi etc etc
                                      Edited: to add a thank you in advance!!!! šŸ¤¦ā€ā™‚ļø
                                      Will Brooks 1 Reply Last reply
                                      • Andy Beviere Andy Beviere
                                        @HABVEN-aka-MrMRA with the greatest of respect that is utter rubbish which is why so many people have been asking the same question for years… and it is literally years now, I can’t believe people are still parting with in excess of Ā£500 for a device and as for that Tread appā€¦šŸ˜‚šŸ˜‚šŸ˜‚
                                        I have had pretty much every sat nav going on my motorcycle journey (forgive the pun) and its only DMD that doesn’t mess with the ā€˜planned route’ this is an important distinction to make, I’m talking about sitting down and planning a cracking ride for example in Spain not using the device to go from AtoB… I plan on here and export to DMD and not once have I had an issue, plan on here and export to the Zumo XT2 and nothing but issues, I could go and on with other examples... couple below for you.
                                        Example: Last year we were having a cracking ride in the Saint Mere Eglis area of France, using Zumo XT2’s next thing we know we’re on a motorway for an hour and a half as the route had been changed, we should’ve been following the ā€˜planned’ coast road. Later in the year I had the same issues on a trip with my wife.
                                        Regards,
                                        Andy.
                                        @Andy-Beviere said:
                                        with the greatest of respect that is utter rubbish which is why so many people have been asking the same question for years… and it is literally years now, I can’t believe people are still parting with in excess of Ā£500 for a device and as for that Tread app…
                                        Andy, I was triggered when I read your original post above. The issue isn't the XT/XT2/XT3 devices -- they do work well. The issue is than many riders (most) who buy the devices never properly learn how to use them. In fairness, it's not easy. The official Garmin documentation isn't great (closer to terrible), and it takes a lot of dedication to experiment and piece things together over time. One of the best resources on the planet is the dedicated Zumo XT forum:
                                        https://zumouserforums.co.uk/viewtopic.php?t=1464
                                        Even there, the information can be overwhelming to absorb. I wish I could write a few paragraphs that would give you everything you need to know, but that's not possible. Especially by Friday. 😊
                                        If you're having that much trouble with an XT (or XT2/XT3), I'd recommend initially staying with MRA Desktop for route planning and the MRA Next app for navigation. The MRA documentation and learning resources are excellent, and there are many forum regulars more than willing to help. The learning curve is much less, and it can be a good entry point to advancing to the XT platforms in the future. Good luck.
                                        • Hans Kremers
                                          Hans Kremers
                                          Hans Kremers
                                          It sounds to me that people who want to avoid their navigation device recalculating the route they planned are actually looking for turn-by-turn navigation on a track rather than on a route.
                                          Unfortunately, very few navigation devices support this. Most devices that offer track-based turn-by-turn navigation are designed for running or hiking and rely on dedicated file formats that contain both the track and the navigation instructions.
                                          For motorcycle navigation, the only solutions I know that provide true turn-by-turn navigation on a plain GPX track are DMD2 and OsmAnd. Of the two, DMD2 is much more intuitive and easier to use, whereas OsmAnd offers similar functionality but comes with a significantly steeper learning curve.
                                          Triumph Tiger 800XCa
                                          Blackview BV6200 / Osmand+
                                          MartinW Andy Beviere John S Parry 3 Replies Last reply
                                          • 3
                                          Andy Beviere
                                          Andy Beviere
                                          Hans Kremers
                                          Hans Kremers
                                          Will Brooks
                                          Will Brooks
                                          Guzt
                                          Guzt
                                          Olivier Weinand
                                          Olivier Weinand
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
                                          • AI Planner: missing number of planned days in Library
