  4. WEB-version of From-To, heavily curved, avoid highway
3 Posts 2 Posters 745 Views 1 Watching
  • Tore Teigene
    Tore Teigene
    Tore Teigene
    On Web version of Route Lab one can create a scenic tour of a certain distance or time based on where you are just now.
    On Android version there is also a scenic tour with options re road quality,
    BUT you also have a From / To version whery you can set options like "how curvy", avoid Highway, avoid ferries and so on.
    This feature would be VERY much appreciated in the WEB-version of Route Lab.
    Reason behind: I am currently planning a trip from Norway to Asti (Italy) and back. It will take us 2 weeks to complete, and i would definitively like some help to locate curvy, small roads for each day of the tour.
    To do this on a mobile is very challenging due to size of screen.
    Any plans?
    • Travellexxie
      Hi Tore, I presume you want to make tour with the web-planner and ride it with the Navigation-app... right? Well with a little work-around and some magic, you can do it right now.
      First set your map on OSM.
      In OSM you can set the "sinuosity" of roads and even of segments of the route.
      When you're done, coomposing your tour, compare the OSM-route with the HERE-map (in your toolkit). Add shapingpoints, so the "HERE-route" is the same as the OSM-route.
      Now change your main-map from OSM to HERE and you're route is exactly how you want it.
      • Tore Teigene
        Tore Teigene
        Tore Teigene
        Ahh. That was a good tip. Very useful workaround. Thanks a lot Lex !!
        Tore Teigene
        Tore Teigene
          Rory Burke
          Rory Burke
