  4. MRA V5.0.3 (449) The contrast is not sufficient
29 Posts 9 Posters 339 Views 5 Watching
    Hello,
    Today I was irritated, the contrast on the map was already better or, that to recognize the different road types and courses when driving...
    • Wong ( Goes like this ) โœ‹๐Ÿค”
    • Dart ( Not better ) ๐Ÿ‘Ž
    • vulf ( No, it doesn't work) ๐Ÿ‘Ž
    In Standard ..
    If an improvement could not be sought here, why is this so difficult, with more sun it will not get better ๐Ÿฅด
    โ—๏ธMRA & BMW Cradel & Remotek One & Navi Halter3D Druck Senkrecht โ—๏ธ
      Okey? Since when has this become an issue? The maps are like this for a long time.
        @Corjan-Meijerink ,
        Just got back from the tour.
        I can't say exactly in the fall of 2025 with the V 4.x.x maybe it was better, or I drove in December 2025 but without the sun, today it was weird.... I checked everything and set the brightness of the IPhone Xr very high to max...
        Feels like it was different, or is the spring sun to blame, but I don't think so!
          I tried to photograph it but with the sun etc. it was difficult and it doesn't really exist compared to the ride ... at the moment the sun is still low.
          • But is there perhaps a possibility of improvement in principle?
            So your screen has a glare in the sun?
            Cannot do much about that ๐Ÿ™‚
            Reading the rpm on your bmw display is hard too with that lighting ๐Ÿ˜‰
            richtea999 1 Reply Last reply
              Okay, so .. basically it would be good to be able to see the small roads better, it's about L and K and smaller roads
              Bild โ€ฆ ๐Ÿฅด
                Yeah, still donโ€™t see the problem ๐Ÿ™‚
                  I will try again on the next tour to make a better picture of the topic to make it visible.
                  That's what it's about:
                  Small streets / very small streets
                  If you are on the road and have zoomed out further, it would be with more contrast or other colors for the small streets then perhaps to recognize them better so that there back, for example, on the right, a beautiful curvy road goes off ....
                  Even at the age (I 66) you need more higher contrast pictures which is not yet an issue for you as a young biker !!
                  But I am only one of many to many of the old users over 60 of the MRA app users.
                  VG and good luck ๐Ÿ‘
                  • Steve 2v
                    Steve 2v
                    Steve 2v
                    For me this has only been an issue on apple carplay devices, the largely white or grey roads when displayed on grey or white backgrounds like Vulf or Wong tend to lack contrast on these displays and make it harder to make out side roads for awareness. There have been posts about this in the past. The Dart colour scheme works better for me. The ideal solution would be to mark the edges of the road - something like a darker edge line.
                    Still the best app though and I like everything else ๐Ÿ™‚ Looking forward to testing the CarPlay enhancements that are coming
                      So, I avoid highways and main roads as much as possible, and these should be clearly visible on the display.
                      Regarding Dart: The major roads, like main roads and country roads, are barely distinguishable; they're both yellow...
                      Regarding Wong: The distinction between highways (red, wider) and main roads (red, narrow) to country roads (yellow) and small roads (yellow, narrow) is definitely a good start. However, the very small roads (white) are barely visible. In rural areas, this makes navigating the beautiful little roads (white) very confusing. If you haven't planned ahead and want to make a spontaneous turn, the road layout (white) is difficult to discern.
                      Example at Mรถhnesee: The forest road, which is "beautiful to drive," is barely noticeable when driving past. It leads to "Franki's Hut," which is highly recommended.
                      Link zur Frankis Hรผtte
                      The turnoff from the south shore to the forest road is barely visible on the display!
                      That then with sunshine is then on the way on the mobile phone / motorcycle often difficult to recognize.!!
                        I understand your point but I can think of a lot of examples where it would be absolutely a terrible idea if those minor roads are shown on these low zoomlevelsโ€ฆ
                          It would be nice if you could turn it on or off.
                          • Showing small streets more would be a solution if that would be against !!
                          With Google Maps such a road is shown better ..
                          unten ๐Ÿ‘‡ MRA
                            Ah, yes. Another setting!
                            • Lluis Arasanz
                              Hi all,
                              If I can say something about maps and colors is when Traffic density is shown.
                              If highway is red (o near red) color, is too difficult when driving to know if a traffic jam is ahead. If highway is yellow, the same with medium density traffic.
                              And even this is worst when night colored maps are used.
                              The rest of visibility, is more about device contrast and screen light.
                              I donโ€™t know how difficult is code this colors or change how traffic is presented on screen .
                              But perhaps an alternated two color layer (red and white for example) can add more contrast to see traffic jam in a fast view to navigation screen.
                              Thanks and regards
                              • BMW F750GS
                              • Guzzist
                                Yes, the missing contrast is really a pitty. About the different colours for streets: I love the "Michelin-Style" in paper maps, because in an overview (less zoom) it's easy to orientate.
                                Highway = red/orange
                                primary roads = yellow
                                local roads = white
                                But yes, in case of traffic overlay (red and yellow) it may not easy to identify.
                                • ConiKost
                                  ConiKost
                                  ConiKost
                                  I also would be very happy, if such option could be considered.
                                  Shiny!
                                    @Corjan-Meijerink said in MRA V5.0.3 (449) The contrast is not sufficient:
                                    1. Anti-glare film on the screen helps a lot. About 15 Euros.
                                    2. Wong + 'Roads only' option in Map Style is quite high contrast (yellow roads on light grey background in light mode)
                                      I can't really take that first
                                      I use that but the contrast is still missing
                                        The contrast is unfortunately chosen...
                                        The small white streets are not really good to spontaneously conquer a beautiful little street unplanned...
                                        Direction stretched by 180"
                                        • ConiKost
                                          ConiKost
                                          ConiKost
                                          I also would like to add, as in comment #19 from Hubert, that those small white roads are really not very good to see. Maybe a litte bit different color could already help to make them see better.
                                          Shiny!
                                          ConiKost
                                          ConiKost
                                          Baltus
                                          Baltus
                                          Steve 2v
                                          Steve 2v
                                          • Opstarten app in Android.
                                            Beemerfrankie
                                            Beemerfrankie
