  4. 5.0.0 (420) on Android Tablet
3 Posts 2 Posters 31 Views 2 Watching
    Hi, there are some problems I noticed with V 420 on my Oukitel Tablet. (I changed toRT3 Pro with Android 14)
    1. I can not move the start menu down in landscape format. It moves min. 1 cm that's all. In portrait mode, it moves down completely.
    Normal view:
    Minimum move down:
    Portrait mode:
    2. WayPoint setting in InApp Routeplanner. In Landscape mode it is not possible to set the WP correct on the street. The WP is set by hand top not by hand bottom. In portrait, it is OK!
    1. Then there is something wrong with the positioning in landscape. Depending on what you are doing on the screen, the centre position (red arrow) jumps back and forth or does not use the centre.
    See video: https://youtu.be/UhGaWx5M0aY
    I start a track.
    The current position then jumps under the menu.
    I tap on Navigate and the current position is outside the screen.
    I tap on the three dots and the position is now correct.
    I stop navigation and start again.
    Now I tap on Navigate a little longer, everything still looks fine.
    Now I tap on the compass to change the view.
    The position jumps to the centre of the screen in all views.
    Normally, the position should be slightly to the right.
    When I tap on the menu, the position jumps to the centre right.
      1: design choice - menu can't (and won't) be able to be moved down in landscape
      2: I'll investigate a bit more (possibly fixed in the upcoming update)
      3: Believe it's fixed for sure in the upcoming update
      Jörgen 1 Reply Last reply
        @Corjan-Meijerink said in 5.0.0 (420) on Android Tablet:
        1: design choice - menu can't (and won't) be able to be moved down in landscape 😢
        2: I'll investigate a bit more (possibly fixed in the upcoming update) 👍
        3: Believe it's fixed for sure in the upcoming update 👍
        • Opstarten app in Android.
          Beemerfrankie
          Beemerfrankie
