  2. New Users' corner
  3. Hi, I'm a new user
Hi, I'm a new user
5 Posts 3 Posters 1.3k Views 1 Watching
  • john anderson 2
    john anderson 2
    john anderson 2
    Hi, I've just registered as a new gold user. I used a trial version in 2018 to plan a trip to Norway, and it worked very well.
    I haven't used it since but i am now planning a trip to Austria in 2021.
    I have just created a basic route, but I am now looking to fine tune it, and wanted to select some of the route options. However, I don't get any choices in the toolkit, all i see is "Routing Options : Off road". Why do I not see the options that were in the lesson 4 video?
    Thank you
    • john anderson 2 john anderson 2
      Thank you
      @john-anderson-2
      Hi John, welcome.
      What map do you use?
      john anderson 2 1 Reply Last reply
      • Paul Pals
        Paul Pals
        Paul Pals
        Hi John, if you are a Basic member then you have only the possibility for the Standaard OpenStreetMap and you can't juse the toolkit.
        Good journy to Austria.
          @john-anderson-2
          Hi John, welcome.
          john anderson 2
          john anderson 2
          john anderson 2
          @Hans-van-de-Ven-MRA-Master hi, i realised eventually that it was a map related issue and have changed to HERE, which solved the problem, thank you.
          • Paul Pals Paul Pals
            john anderson 2
            john anderson 2
            john anderson 2
            @Paul-Pals hi, i am a gold member but i hadn't realised about the map types, i have changed to the HERE map and that has fixed the problem, many thanks.
            Paul Pals
            Paul Pals
            john anderson 2
            john anderson 2
            • Startpunt wijzigen
            • V6 - Track Navigation
              Thomas Schäfer
              Thomas Schäfer
              1.7k
