  4. Beta Planner - What "Exactly" Happens to My Existing Routes
9 Posts 5 Posters 220 Views 2 Watching
  • BMcG
    If I were to subscribe to the web planner beta what exactly would happen to my existing routes?
    I believe there is some kind of transfer from the classic web planner to the beta planner but unsure of the details
    Does my whole classic existing library of routes get transferred to the beta?
    Do my existing routes get removed / deleted from my classic library?
    Do I end up with 2 completely independent copies of the route, one in the classic planner & one in the beta planner?
    If I create a route in the beta planner with the usual informative detail with Via points, coffee, lunch, viewpoints notes & fuel stops with icons etc, I believe this is only visible to other beta participants I share it with within the beta
    Is there a way to sort of reverse transfer a lovely detailed beta planner route back to the classic planner so that it can be shared with existing friends & groups? (I dont want to loose the detail so gpx is NOT an option)
    • BMcG BMcG
      Yes they do
      No they don't
      Yes you will and you can edit the one in the Beta without changing anything to the one in the classic version
      Correct for the time that the Beta has not gone public, so after 15 february it will be for everyone
      If you intention is to share that route with someone not having the Beta option at this time, you could export the route in Beta using the 1.1 format to share it with your non Beta friends. I'm not 100% certain if alle the wonderfull details will be included in that export.
      BMcG 1 Reply Last reply
        Yes they do
        No they don't
        @Marinus-van-Deudekom thanks for the comprehensive reply
        it does raise the question for me what happens in February if I have the same routes in 2 libraries .i.e. the original route in the classic library & the new copy in the beta library
        do I end up with 2 copies of the same route after the 15th February or is the system going to be smart enough to recognise they are identical & only leave 1 copy?
        if i edit both routes before 15th february i.e. the one in the classic library & the one in the beta so the routes are slightly different but the names of the routes are the same what happens?
        • BMcG BMcG
          @BMcG in time the2 will be merged to 1
            @Marinus-van-Deudekom not really.
            After February 15th the beta will become the new website 🙂 So if you’ve already transferred your data to beta, you are fully prepared.
              wrote last edited by Corjan Meijerink
              The old website will remain accessible for a while but it will shutdown eventually (few months)
                @Corjan-Meijerink ok but if the 2 sites are not mergel to 1 that raises the questions what will happen to those users that haven’t moveren on to the Beta site.
                There are users that don’t use the planner for a long long time
                  @Corjan-Meijerink that is clear; however, every answer gives rise to new questions. I do not have beta access. When I launch the planner on February 16th:
                  • Will there be a different URL, or will the old site be assigned a new URL (something like "old")?
                  • What will happen to all the links to routes that are currently posted elsewhere, once the old site goes offline?
                  • Will all my routes have been transferred to the new site by then?
                  • paul69
                    going to follow this thread closely. hopefully the routes will be automatically transferred, (obviously user to be informed of this when it happens)
                    personally and like many others, I have numerous folders each with many many routes, it will be a bit tedious to have to download them one by one and copy into the new planner.
                    I imagine the devs are on top of this, and there will be nothing to worry about.
                    Might just start to copy to dropbox just in case.
                    K1600 GTL
                    iPhone 13 Pro, carpuride 702b
                      MartinW
                      MartinW
                      MartinW
                      MartinW
                      Rory Burke
                      Rory Burke
                    • Béta to no-béta
