  4. Keep all routes visible when editing a route from a library folder
8 Posts 4 Posters 94 Views 2 Watching
  • TorqueRider
    Suggestion: Keep all routes visible when editing a route from a library folder
    When planning a multi-day trip, it is very useful to have all routes in a selected library folder visible on the map simultaneously, each with its own colour. As is currently possible in the current Beta Planner.
    However, in the current Beta Planner, selecting a route for editing causes the other routes to disappear from the map.
    I would like to suggest an improvement to this workflow.
    Proposed functionality
    When a library folder is displayed on the map:
    • Keep all routes in that folder visible, each with its own colour.
    • Allow the user to select an individual route directly on the map for editing.
    • When editing that route, keep all other routes visible as references.
    • Allow the user to switch directly to another route by selecting it on the map, without having to return to the library folder. And still keep all other routes visible as references.
    Why would this be useful?
    When planning a multi-day motorcycle trip, maintaining an overview of the complete journey is important.
    For example:
    • Am I using the same roads on multiple days?
    • Am I unnecessarily repeating sections of a route?
    • Is there a more logical way to connect two consecutive days?
    • Which day's route would be the most practical one to modify?
    Being able to edit individual routes while keeping the entire journey visible makes it much easier to assess the overall route structure and make informed adjustments.
    The key point is that all routes should remain visible as references, while allowing the user to select and edit any route directly from the map.
    This would be a valuable improvement to the workflow, particularly for users planning longer, multi-day trips.
    • HABVEN aka MrMRA
      That is a good one 👍
      • TorqueRider
        @corjan-meijerink or @nick-carthew
        Unfortunately, I posted this proposal in the wrong forum.
        It should, of course, have been placed in the MRA Routeplanner Next Beta forum.
        Perhaps a moderator could move it to the correct forum?
        • Nick Carthew Nick Carthew moved this topic from [App-Beta] Suggestions and Discussions
        • TomOnTour
          TomOnTour
          TomOnTour
          I like the concept , so a +1 from me.
          A small suggestion from me:
          I thnik it would be great, if you can switch this "feature" on and of within the planning screen. Sometimes it would be helpfull to remove the other rooutes for a moment to get a better view on the route you are currently editing.
          The idea is: Lets have a small button or command to hide and un-hide all other routes.
          MyRoute-APP Navigation Next (V6.0.0 - 489) on DMD T781
          using iPad Pro (iPadOS 27.2.1) and Macbook Air (macOS 27.2.1)
          • John Matthews 0
            John Matthews 0
            John Matthews 0
            This is how I work with the current functionality.
            I use the application to plan long trips in my camping car. In a trip of say 21 days, this would involve 8 driving days in the camping car and 10+ days where I use the app for planning and tracking hikes.
            For the driving, I initially plan a single route. Only when I have a feasible trip that I am reasonably happy with, then and only then, I split the route into the daily stages. Currently, if I want to make modifications I have to use the summary route, because when I last tried, working on the daily stages is not sychronised back to the multiday parent. My understanding is that this is being implemented. When it is, I would make minor changes on the daily stages and if multiple stages were impacted use the summary parent.
            John
            • John Matthews 0 John Matthews 0
              John
              @John-Matthews-0
              I don't think you need the same solution as the one I am proposing.
              My question is about a solution that works particularly well for multi-day trips starting from one or two locations. For example, in a situation like the one I am showing a screenshot of here.
              • John Matthews 0
                John Matthews 0
                John Matthews 0
                Yes - you are correct - the situation you show is different. If I am correct you are showing 3 three locations and from each location you have multiple routes. It is however possible to have a folder view with a complete route and highlight stages providing you highlight the complete route first like so ...
                I believe you could use this same method for sets of circular routes from different locations by using nested folders, but to go from the map to the routes you would need the map to have links which would require additional functionality
                John
                  John
                  Nope 😀
                  In this case, it concerns a holiday from 2012 (hotel 1) and another from 2014 (hotel 2). Next year, a friend will be doing all 6 routes during his own holiday (hotel 3). Perhaps I chose a poor example, as this scenario is somewhat complex.
                  However, you can encounter similar issues with many multi-day trips based out of a single location.
                  In any case, thanks for your input 👍 . I’m likely familiar with every workaround by now, and my proposal seems like a solid solution.
                  John Matthews 0
                  John Matthews 0
                  TomOnTour
                  TomOnTour
                  • Move a GPS point on the map
                    MartinW
                    MartinW
                  • Stopover expiration time notification
                  • MyRouteApp on the Tracer 9 GT+ Display. Works! :)
