1 post all Bugs & suggestions
Hi @corjan-meijerink as you suggested this post will be for all Bugs or suggestions. Please don't lock it so I can keep on adding as I plan.
(This will be all phone planning on Android Oneplus 12.)
Remove from map too low to tap.
Can you add an option to adjust the transparency make darker or see through.
Can you please add the alternating blue and white lines for each day. Makes it easier to distinguish and looks familiar.
Can you remove that bit at the bottom it'll look much tidyer and give a bit more space on the map.
Can you please add Supermarket to (Discover)
I'll add more when I come across them please don't lock
Can't change this viapoint to waypoint. When I placed it on the route it didn't give me the option to select waypoint.
@JP-d That makes sense, it's the last waypoint
So via by definition -
Processed the first feedback round!
So via by definition@Corjan-Meijerink. Thanks mate. Amazing stuff
. The viapoint isn't the last one if you see my hotel was charged to a waypoint and this one became a viapoint. Even thought it was placed on the route before the hotel.
With your input, this post could be even better đ
