F019 WebPlaner - MRA V6.0.0 (531) - POI delta detected
Unfortunately, I just discovered that by chance..
I added a nice new POI today; in the new beta WebPlanner—see image 1—everything is exactly as it should be. The web link and the address were both imported automatically and saved accordingly. A fantastic feature in the WebPlanner now!
When I open this specific POI in the new MRA V6.0.0 (531) app, some information is missing—information that I find quite useful. The links, which appear clearly in yellow in the WebPlanner, are completely absent; see image 2 for reference.
Is this intentional? I suspect not, as being able to click a link to a venue directly from a POI on the map is extremely helpful when you're out and about.
It seems that the data—shown in image 3—isn't being transferred to the correct field for display within the app when performing a search... or something along those lines?
Bild 1 im WebPlaner: POI - "Wein - Onkel Tom's Hütte"
Bild 2 in der App: POI - "Wein - Onkel Tom's Hütte"
Bild 3 data found .. which are stored in the POI within the Web Planner.
Copying goes...
If I copy this from below in the description, it also works great in the app
The POI has a description field, if I copy the three contents there, the app also displays it ... you could do that automatically, right?
@corjan-meijerink : Now I’m a bit confused... regarding this location on the map—it was actually a good example.
I moved the POI to a different group and tried to re-add it, just as I did yesterday in the example group, but now the data no longer appears when I click on this location. Have there been any changes to the underlying map data—perhaps to prevent it from being used because it’s not always reliable—or why has the data suddenly gone missing ?
That’s how it was yesterday ...
