  4. Maps Michelin
Maps Michelin
23 Posts 15 Posters 3.0k Views 7 Watching
    Hello
    I can not see the michelin maps when I zoom under 100m
    Is it the same for you ?
    CLE 0
    CLE 0
    CLE 0
    @LE-DIZES-Freddy
    It's the same for me : Firefox, MacOs
    • Tegel Werner
      Bei mir auch! Safari Browser. Ausserdem gehen MRA Scenic und Verkehr nicht mehr.
      • Thomas Neumeyer
        Thomas Neumeyer
        Thomas Neumeyer
        Bei mir funktioniert die Michelin-Karte auch nicht mehr.
        • Garry Davis
          Garry Davis
          Garry Davis
          Me too Google Chrome on Windows 11,. No Michelin maps
          • Thomas Schäfer
            Thomas Schäfer
            Thomas Schäfer
            I’m having exactly the same issue with Google Chrome on Windows 11. Not all of them, but some tiles are missing and won’t load, even with a bit of patience.
            Freundliche Grüße/Kind regards/Met vriendelijke groeten
            Thomas
            • Jacob Waterweg
              Jacob Waterweg
              Jacob Waterweg
              Same in Chrome on Android. In the left bottom corner is the measurement. 100m and above show the map correct. More zoomed in, 50m or lower, the map is (partly) gone.
              Motor 1: MRA op Ulefone Rugking Pad Pro met Android 16
              Motor 2: MRA routes op TomTom Rider 550
              Auto: MRA op Android Auto vanaf Motorola Edge 50 Fusion met Android 16
              • Pierre c
                Pierre c
                Pierre c
                I have the same problem on Firefox/Windows 11, but I can't zoom beyond 2 km. Will the MRA address this issue?
                • Christophe Brion
                  Christophe Brion
                  Christophe Brion
                  hello, i have the same problem. When i zoom, i have un gray display.
                  • Ed Lauwerens 0
                    Ed Lauwerens 0
                    Ed Lauwerens 0
                    Same here.
                      The issue has been resolved 😃
                      • Stanisław
                        Now it doesn't work for me at all:
                        Staszek
                        Jörgen 1 Reply Last reply
                        • Stanisław Stanisław
                          wrote last edited by Jörgen
                          @Stanisław sagte:
                          Make a complete refresh with F5.
                          (Normal Refresh)
                          • Windows / Linux (Chrome, Firefox, Edge): F5 or Strg + R
                          • macOS (Chrome, Firefox, Edge, Safari): Cmd + R
                          For it works after this.
                          • Jacob Waterweg
                            Jacob Waterweg
                            Jacob Waterweg
                            Inderdaad. Ook op mijn Android kan ik weer inzoomen op de Michelin kaart zover als ik wil. Heerlijk zo'n ontwikkelaar die actief meeleest👌
                            • Stanisław
                              @Jörgen napisał:
                              (Normal Refresh)
                              I made it several times, even cleared browser cache, no effect in FF. The problem was NoScript add on, which started to block some Michelin script, now unblocked and works again perfectly 🙂
                              Staszek
                              • Thomas Neumeyer
                                Thomas Neumeyer
                                Thomas Neumeyer
                                Hi, it behaves very strange now and does not look like the "old" Michelin map.
                                  Hi, I do see only small difference.
                                  MRA map with Michelin
                                  Michelin map original
                                    LE DIZES Freddy
                                    LE DIZES Freddy
                                    LE DIZES Freddy
                                    @Corjan-Meijerink merci
                                    • Thomas Neumeyer
                                      Thomas Neumeyer
                                      Thomas Neumeyer
                                      Hi Jörgen, hmmm ok, maybe I am wrong. Will check again. Thanks Thomas
                                      • simone treglia
                                        simone treglia
                                        simone treglia
                                        buongiorno, a voi si è risolto il problema della mappe michelin? io non la visualizzo.
                                        ho provato con crome, edge e firefox. grazie
                                        simone treglia
                                        simone treglia
                                        LE DIZES Freddy
                                        LE DIZES Freddy
                                        Ed Lauwerens 0
                                        Ed Lauwerens 0
                                        Thomas Schäfer
                                        Thomas Schäfer
                                        Jacob Waterweg
                                        Jacob Waterweg
                                        Garry Davis
                                        Garry Davis
                                        Thomas Neumeyer
                                        Thomas Neumeyer
                                        Christophe Brion
                                        Christophe Brion
                                        Pierre c
                                        Pierre c
                                        CLE 0
                                        CLE 0
                                          Michael 2v
                                          Michael 2v
                                        • Hide warnings on the map
                                        • Bollard trouble
                                        • Map Layers
