  3. best format to download
5 Posts 5 Posters 101 Views 2 Watching
  • Mike wiruth
    Mike wiruth
    Mike wiruth
    Hello, What is the best format to download? Not only for using offline maps but for transferring to my garmin xt?
    Thanks
    Mike W
    2013 Honda Goldwing
    Bushtec Trailer
    Garmin Zumo XT
    Nebraska
    • Mike wiruth Mike wiruth
      Thanks
      @Mike-wiruth The standard and recommended format is GPX 1.1
      However, this isn't necessary at all for using the MRA Next app offline.
      The important thing is that the maps are available offline and that the routes are synced.
      Everything else works automatically when you navigate with MRA Next.
      If you're absolutely sure you don't have cell service, you can also navigate completely offline right away.
      To do this, simply go to the app's navigation settings, select “Route Calculation,” and enable the “Offline Navigation” option 😉
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
        When you (still) use Basecamp I would recommend GPX 1.1 (route, track, POI).
        You can then plan the route using the ‘recalculate’ option and afterwards easily check for any discrepancies against the track you’ve recorded. If you send the route and track from Basecamp to the GPS via a cable, you can be sure that everything stays the same.
        I’ve been doing it this way for years and have never had any problems with the route!
        • Travellexxie
          wrote last edited by Travellexxie
          Ok, another sound: I prefer the 1.2 for my XT(1), because it fits exactly to my preferences: the route is based on a track, all viapoints are in the route, pauses you add to routepounts are added tot the ETA, so you know exactly when to tell your wife when to prepare dinner 😂
          • John S Parry
            Another 1.2 fan here. If you’re running your route on an XT, XT2 or XT3, what you create on MRA Routeplanner is recalculated the same (without fail) on the Garmin.
            Mike wiruth
            Mike wiruth
            • New Zealand Routes
            • Getal in begin logo
            • best format to download
            • Opknippen route in etappes
            • routeXpert
            • Naar vorig routepunt
