  3. best format to download
3 Posts 3 Posters 21 Views 2 Watching
  • Mike wiruth
    Mike wiruth
    Mike wiruth
    Hello, What is the best format to download? Not only for using offline maps but for transferring to my garmin xt?
    Thanks
    Mike W
    2013 Honda Goldwing
    Bushtec Trailer
    Garmin Zumo XT
    Nebraska
    • Mike wiruth Mike wiruth
      Thanks
      @Mike-wiruth The standard and recommended format is GPX 1.1
      However, this isn't necessary at all for using the MRA Next app offline.
      The important thing is that the maps are available offline and that the routes are synced.
      Everything else works automatically when you navigate with MRA Next.
      If you're absolutely sure you don't have cell service, you can also navigate completely offline right away.
      To do this, simply go to the app's navigation settings, select “Route Calculation,” and enable the “Offline Navigation” option 😉
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
      • white.mouse.on.the.motorbikegmail.com
        When you (still) use Basecamp I would recommend GPX 1.1 (route, track, POI).
        You can then plan the route using the ‘recalculate’ option and afterwards easily check for any discrepancies against the track you’ve recorded. If you send the route and track from Basecamp to the GPS via a cable, you can be sure that everything stays the same.
        I’ve been doing it this way for years and have never had any problems with the route!
        Mike wiruth
        Mike wiruth
        • New Zealand Routes
        • Naar vorig routepunt
        • best format to download
          JP d
          JP d
        • Off-road niet zichtbaar in Android Auto
        • IOS 27
          Stephen Rowland
          Stephen Rowland
        • How do you download maps
