  4. Opening Route Direct from Android Auto Screen
9 Posts 6 Posters 582 Views 3 Watching
  • Andrew Dickerson Offline
    Andrew Dickerson
    When opening a route on the AA screen direct it does not give you an option to choose next waypoint (on the phone it automatically chooses waypoint 2, which is correct). On the AA screen it defaults to 1 (which in my case us my home/start) - this then considers the route complete before you're started.
    • Andrew Dickerson Andrew Dickerson
      Marinus van Deudekom Offline
      @Andrew-Dickerson if you mean that you would like to choose between the start or the nearest shaping point. That you must set on your phone itself
      • Karl-Heinz Schwendner Offline
        For me the same issue - it's set on the phone to start with the nearest shaping point and use the current location.
        But when I start it on my Carpuride it always wants to start with point 1 !
        You can skip route point - but can't see at the carpuride (android auto) how many point you have to skip!
        It's absolutely frustrating!
        • Mzokk Offline
          Mzokk Offline
          If you start the route in AA then go to the gearwheel select waypoints then select the waypoint you want to start at then go back to the navigation screen.
            • Karl-Heinz Schwendner Karl-Heinz Schwendner
              @Karl-Heinz-Schwendner look at what @mzokk posted and you can see a work around. In that way you can see the list of waypoints hence choosing the one you want
              Karl-Heinz Schwendner 1 Reply Last reply
              • LennyO Offline
                LennyO Offline
                Better yet, do not start your route right at your house. Have the Waypoint #1 a few hundred feet along the intended route (I doubt you need navigation instructioins around your house or on your street... 🙂 ). This way you will eliminate 2 issues at once:
                1. Missing a Start (which is a Via point) and be sent back
                2. Manual intervention to skip WP #1 or selecting any other place to start from.
                • LennyO LennyO
                  Hubert Thoring Offline
                  @LennyO sagte:
                  Very important and correct the hint, because it is often done wrong and leads to problems if not observed
                  iPad 9. Gen iOS 26.6.2/ iPhone 16e iOS 26.6.2/ Navi iPhone Xr iOS 18.7.10 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
                    @Marinus-van-Deudekom thanks for the hint - but never heart the word gearwheel before for the settings icon 🙈
                    so it took a while to detect how toget to the waypoints.
                    But now I think it's fine and a working workaround for this issue.
                    Andrew Dickerson
                    Andrew Dickerson
                    • The slow death of Zumo...
                      Arno van Lochem - Senior RX
                      Carl Lee
                      Carl Lee
                    • Rejoining routes
                    • New Zealand Touring Group
