  4. Offline Track Navigation - Path Errors with Large Distance Between Points
5 Posts 3 Posters 632 Views 2 Watching
  • Brian McG
    I know this is not normal & not how MRA is intended to be used, in fact it could be said to be bad practice or poor planning but I think this example may give a clue to why there are complaints about MRA unexpectedly deviating from highways
    There is something strange in the path calculation that goes wrong when the distance between 2 points is large ~>80 miles (130km) if Offline & Track navigation are enabled
    The calculated path can/will deviate from a simple direct path down a motorway to leaving via an off ramp, re-routing around a load of side roads & sometimes even jumping up/down off of elevated roads before continuing
    To test this I simply create a 2 point route larger than > 80 miles starting at an on ramp & finishing at an off ramp
    The web planner will show me a distance & time for the route
    Open the route in the App & the same distance & time are displayed before the navigation is started
    When the navigation starts the route is recalculated & it is immediately obvious that something is wrong because the mileage & time increases
    Inspecting the new calculated route, incorrect / unexpected deviations off of the motorway are easy to find
    Shorten the route so it includes the areas where the unexpected deviation occurred & the path follows the correct direct route along the motorway
    It is the large distance/time between points that seems to cause the unexpected deviations
    Online & disabling track navigation the problem does not appear
    It has nothing to do with traffic or road works
    I don’t really care / am not expecting a fix for this as I rarely plan trips with large sections of motorway,
    it is just something I noticed when testing to try & answer this other question on the forum
    Just thought maybe as it is a very reproducible error it may give a clue as to where in the path calculation sometimes an error can occur
      I don't think it's a mistake; you really should check the track navigation settings before setting off—this is something you can and generally ought to do before starting a route or track. In your case, it is indeed track navigation, since you are talking about a route from point A to point B. Track navigation assumes a route with at least some curves—meaning it generally avoids motorways. Even if you start by getting onto a motorway on-ramp, the system will always take the next logical exit to get you onto a more winding route.
      VG
      Siehe die Fotos:
      Selection slightly curvy ..
      Avoidances …
      Brian McG 1 Reply Last reply
        VG
        Siehe die Fotos:
        Avoidances …
        sorry @Hubert-Thoring the routing all seems to work perfectly with a 2 point route if it is a shorter distance
        WITHOUT changing any settings, just increasing the distance the routing calculator will suddenly start taking crazy detours
        this has nothing to do with motorway per-se, the motorways are just an simple repeatable way to demonstrate the issue & make it easy to see where the routing calculator goes wrong
        it is very simple for anyone to test, just create a 2 point route far enough apart & try to navigate it as a track offline
        for me the fact that these detours can occur points to a problem somewhere in the routing calculator / algorithm
        as it is very repeatable problem I would think it relatively simple to find the root cause
        fixing the root cause of this issue may also resolve other routing glitches of which we hear of many on this forum
        thanks for the reply
        • Brian McG Brian McG
          seems distance is not the main factor with this oddity, it can also occur for a simple 2 point route with <20 miles between them
          increasing the distance just makes it easier to spot as there are more opportunities / a higher probability of it going wrong
          simply moving point #2 half a mile further up the road results in the calculation for the offline track navigation route deviating by 3 miles when the navigation is started
          the only settings enabled are "offline navigation", "navigatie route as track" & "use all waypoints"
          no other settings are enabled or changed between tests
          it appears the oddity is a bit random but somehow related to distance
          • paul69
            A few weeks ago I rode a route that I have done many times.
            on this occasion the NN did exactly as you describe here. tried to send me off and back on the motorway at almost every junction.
            I had 1 start point 400m away from my house and the next shaping point was located at the end of the motorway section. I did not need anymore as I know the route, it was a means of getting to the twisty toads and these two points were circa 50miles (80KM) apart. only reason I had the two initial points was to give me a rough arrival time. route as track
            I sent the log files to the devs, did not get an explanation, which I wasn't really looking for, the answer I received was, they would use the findings from the log files to help with updates. which was my intention when I sent the log files.
            curiouser and curiouser
            K1600 GTL
            iPhone 13 Pro, carpuride 702b
            • Audio cuttet via Bluetooth
              Haug
              Haug
              35.5k
            • Download club route folders
            • One crash today
            • Elektrisch rijden
              John mq
              John mq
