  3. Anyone tried Ridernav R7M with MRA via AA yet?
64 Posts 10 Posters 16.8k Views 4 Watching
    All Carplay and Android Auto device are sort of the same. The limitations on the devices does not come from the brands but they come from Apple and Google.
    There are lot of brands, screen sizes, screen ratios and resolutions.
    Take a look at the specs of popular brands like Chigee and Carpuride. These specs simply work. Every other brand which has more or less the same spec, should behave the same.
    Max screen brightness is one of the big differences between the devices. Which results in different prices. Because the screen is one of the major parts of a device.
    • LennyO LennyO
      @PieterG Thank you for this, as the carplay area is totally new to me. I use Garmin for years, but now want to run the MRA Nav, because I di believe that it it the best and has grteat future to get even better!
      So may I ask you ( or anyone else) to tell me the 2 top carplay options to run MRA NAV (as in the best / closest screen layout with the least screen functionality lost, while having a bright and readable screen, and work with the Wonder Wheel) in 2 scenarious:
      1. Cost is no factor:
        A?
        B?
      2. Staying on the reasonable budget (sort of like R7M).
        A?
        B?
        Thank you!
      PieterG
      PieterG
      PieterG
      wrote on last edited by PieterG
      #41
      @Lenny-O
      I used to use TomTom Rider long time ago and after that a BMW Navigator IV(=Garmin-ish) for many years. But the BMW Nav's all get the same 'ghosting' problem after a few years and they become unusable.
      (Repair costs 150 Euro every time) This is why I started my search for a follow-up solution and I ran into the same things as you are now 😉
      I started testing all kinds of models and brands of Smart Displays with MRA, Google Maps, Sygic, Waze, Calimoto, Stegra .io and Kurviger using both Android Auto and Apple Carplay on several Android phones and iPhones.
      My opinion: all AA and AC implementations are still premature today (missing functions, etc.) and most nav apps are ok, but I'm the most unhappy with MRA app due to crashes (6-8 times a day, complexity and a very high risk of incorrect settings or operation due to the unintuitive GUI and too many (unclear or fatal) options. (The MRA app should have a “Simple Mode” button to put it into ' Kurviger mode' to make it rock solid usable! 🙂 ).
      Also, most important, with MRA you can NOT ride seamlessly through mountainous areas without an internet connection! (If you turn of data on your phone, MRA will not be able to do what you need..)
      If the aviation industry used software like this, all the planes would fall out of the sky!
      But hey, this is just my opinion after 3,000 km of testing the MRA app....
      The MRA route planner website is very good though, once you get used to it.
      After all of this, I’m happiest with Kurviger: simple, stable, everything you need right at your fingertips without having to search for it. The only thing you should always do when riding a turn-by-turn route, in my opinion, is turn off automatic recalculation. Do that, and it works rock-solid like a charm!
      And with Kurviger you can ride seamlessly through mountainous areas when the Internet connection fails!
      I use Kurviger app with both Android Auto and CarPlay. With CarPlay, the buttons are positioned on the left side of the Smart Screen, while with Android Auto they are at the bottom, which unfortunately wastes valuable screen space. So I prefer Carplay but Android Auto is also fine.
      There is no way at all you can get an exact copy of any of the phone app-views on a smart display. The AA/AC layer is simply preventing that. (for all apps)
      Options with Wonderwheel support:
      1.A Chigee aio 6
      1.B Chigee aio 5
      2.A Ridernav R7M.
      2.B. ...... none
      2.C to Z. See Youtube and look for channel 'Smart Riding Gadgets' for all kind of tests (keep in mind that you are only interested in the models with Wonderwheel support)
      LennyO 1 Reply Last reply
      • PieterG PieterG
        @Lenny-O
        1.A Chigee aio 6
        1.B Chigee aio 5
        2.A Ridernav R7M.
        2.B. ...... none
        #42
        @PieterG Thanks again, Pieter!
        My set up today is MRA Planner, MRA Nav App route xfer to Zumo XT via Garmin Drive.
        I have been running the MRA NAV in parallel to the Zumo XT for about 2000 miles now.
        I must say that MRA NAV performed quite admirably and 95% of discrepancies were caused by the user error (me) or misunderstanding / lack of in depth understanding of the features and settings.
        So, I am quite comfortable and confident with the MRA NAV and that's why I just wanted to get a larger and brighter unit.
        As far as navigating with MRA when the Internet is not available - this is no issue at all, really!
        As of today, as long as your routes are Synchronized - they are available for off-line navigation, provided you have downloaded the maps you need to run the routes.
        You don't even need the Internet to kick-off the route, like it was before in the prior releases, just be Synched.
        I love the new features of running a route as a track for one, it's amazing!
        So, I am a big fan and supporter of MRA and really love the fact that it is a living-thing, developing and evolving unlike others that are stagnant or deprecated by now....
        I think I will stick to my current setup for now and see what developes in the near future 😉
        Thank you for your thoughts!!!
        PieterG 1 Reply Last reply
        • LennyO LennyO
            A?
            B?
            A?
            B?
            Thank you!
          @Lenny-O All the pros and cons of AA and CP have now been set out here in sufficient detail.
          Perhaps you should broaden your horizons a little in your search for a new device and find out whether a 7-inch tablet might be the better choice.
          It offers the screen view you’re used to, with none of the limitations of AA or CP; it offers unbeatable brightness and can be operated using various controllers.
          Yes, all that does, of course, cost a bit more than a device that simply reflects, but it leaves nothing to be desired😉
          DMD-NOR7E GPS Navigation Tablet powered by Android https://share.google/iNnI6e1M6ppbT5yiC
          Motorcycle GPS Navigation Kit | Caretta | 7" Adventure GPS https://share.google/GQvgCAMUf2BTj81Y0
          I’ve had the NOR7E for two weeks now, and I’m wondering why I didn’t go down this route sooner.
          BMW R 1250 GS
          DMD-NOR7E 7"
          SPC Universal mount
          Motorola Edge 40 "offline"
          Sena SLR 3
          Sena 50 R
            #44
            Did you consider the Caretta? Just a neutral question.
            Want to use the Caretta for the next bike but it look the Nor7E is also very intresting. Both has gone their own way which causes differences.
              @M.-Schrijver Yes, of course… a friend of mine has one…
              He opted for the Caretta because he wants to be able to zoom with the Wonderwheel.
              I, on the other hand, already have the Silverfox C1, so I went for the NOR7E.
              The Caretta is much bulkier and the mount is quite heavy-duty.
              And the NOR7E comes with a full licence for the DMD software – that was another reason I chose it.
              I wouldn’t be without it now 😃✌️
              BMW R 1250 GS
              DMD-NOR7E 7"
              SPC Universal mount
              Sena SLR 3
              Sena 50 R
              • LennyO LennyO
                PieterG
                PieterG
                PieterG
                Hi Lenny,
                I think MRA will work excellently on a tablet. (then you won't be bothered by all the AA/AC limitations and freezes)
                Regarding navigation without an internet connection: I have tested this extensively. Naturally, with the latest updates, maps downloaded, MRA in offline mode, phone equipped with the latest firmware, etc. etc., and the data connection on my phone, and thus the Internet, was also disabled.
                I can assure you that I received notifications many times from the MRA app itself (!) that it could not reach the server, as well as other error messages indicating that the connection was missing. The most annoying part: navigation did not work until I reactivated the data/Internet connection.
                I was able to reproduce this problem multiple times, after first rebooting all equipment, so it was a thorough test.
                This is what happened to me for days on end. God only knows what caused it...
                (for the record: I haven't experienced these problems with other apps, so hardware and/or configuration errors can be excluded)
                Additionally, if you are in an MRA group and a shared route has been created within that group and you need to reload that route (like what happened to me when the MRA app crashed in conjunction with AA/AC for the umpteenth time), then MRA obviously doesn't see the group without an internet connection, with the result that you don't see the group routes either.
                So if you are riding in the mountains and have no connection, it's game over for your ride. You therefore have to download those group routes in advance. That is possible, but it takes some searching to figure out how to do it and where the file is located. (but then again, you do run the risk, for example during a multi-day trip, of not having the latest version on your phone if the group administrator has made a last-minute change to the route...)
                Good luck finding a suitable solution for yourself!
                • PieterG PieterG
                  Hi Lenny,
                  I'm sorry you've encountered these problems......
                  But God has nothing to do with it.... The problem stems from a lack of user knowledge and, as a result, incorrect usage.
                  Offline navigation works perfectly, just as Lenny described.
                  The fact that you haven't had any problems with other apps doesn't mean MRA is to blame if you've encountered issues.
                  Every app has its own quirks and settings, but if those aren’t set correctly or if mistakes were made while using the app, you shouldn’t blame the app itself.
                  Please don’t get me wrong… even with MRA, not everything is perfect, but your description shows me that user errors were definitely made.
                  BMW R 1250 GS
                  DMD-NOR7E 7"
                  SPC Universal mount
                  Sena SLR 3
                  Sena 50 R
                    Every app has indeed their own quirks. But to my opnion. MRA must be used in a smaller bandwith to get to work correct. There is less room for user errors for the app to handle.
                    Other apps can handle user error better without giving problems.
                      PieterG
                      PieterG
                      PieterG
                      #49
                      Hi Peter,
                      I believe I only described my experiences, right?
                      Somewhere earlier I also wrote that I think MRA should have a 'simple mode' button (or 'Kurviger mode' 😉 ) for impatient suckers like me. So that the chance of user errors fatal to your route is reduced to a rock-solid app. You don't have to agree with me, no problem. But this is my conviction.
                      And regarding the question of whether or not God has anything to do with this: that just depends on what you believe, doesn't it? If it wasn't God, then is must be the devil😉
                      • Ed Lauwerens 0
                        Ed Lauwerens 0
                        Ed Lauwerens 0
                        OK, I promised feedback on using the RiderNav R7M on a 8.500 km trip to Noordkaap last June 2026. I drive a BMW R1300GSA and use the R7M with Apple CarPlay. My iPhone, on which I run the MRA app, is in my top case, connected to USB power.
                        Overall, I am very pleased with the R7M. The screen is very clear and big, it has a touch screen function which is very convenient and works much faster than using the WonderWheel.
                        First, I had stuff to learn about the MRA app. I found that on remote places, the MRA screen would go blanc (buttons were there, no map however). I learned that I had to download the maps of the countries where I rode and put the app on off-line, than all went well from there on. The R7M experience. First of all, there was always good CarPlay connection - just start the bike and after a jew seconds, the MRA screen would pop up. Switching to Apple Music for starting music en switching back to MRA, just by touching the screen, perfect. During 4 weeks of riding, it happened 3 times that while riding, the R7M just restarted. Screen goes black and starts up again. You don't have to do anything, it comes back on immediately itself. Not a real issue, but I mention it anyway. What happened more often, is that the connection with the WonderWheel stopped. Restarting does reconnect the connection, but not nice. It happened once every 2 days of riding. In the end it was no issue for me, because using the Wonderwheel to navigate the buttons in CarPlay is a hassle. I found out that using the touch screen is soooo much easier, I never uses the Wonderwheel anyway. So, overall I am very happy and do recommend the R7M/Carplay/MRA combination to all BMW drives. A great screen for a very competitive price in my opinion.
                          PieterG
                          PieterG
                          PieterG
                          Exactly my point.
                          Let’s just say that is why I personally am not a good match for MRA. (though I am with a range of other navigation apps, that’s for sure 😉) Simply because I don't want complexity when I'm out on the road and want to focus on the experience of the ride, instead of navigation support that keeps pulling me over because I’ve probably done something wrong again.
                          However, the fact that my setup crashes 6 to 8 times a day makes it unusable for me (for me, that is).
                          I don't experience these crash issues with other apps, so that is where my driving pleasure lies.
                          • Ed Lauwerens 0 Ed Lauwerens 0
                            PieterG
                            PieterG
                            PieterG
                            @Ed-Lauwerens-0
                            Wow, great story!
                            Unfortunate for you that the Ridernav R7M malfunctioned a few times. (To date, 3000km, I haven't had these problems)
                            I completely agree with your conclusion, the Ridernav R7M is the best you can buy for the price😀
                            (Aspirants, take note: it is always available with a 25% discount)
                            • LennyO
                              #53
                              Can someone please, give me a complete list of buttons / features I would not see running MRA Nav App on R7M, compared to what I am used to seeing on the Phone.
                              In my quick test I just noticed a few.
                              Any other quirks or issues I need to know running from my Android S25 Ultra?
                              Any hints dealing with "issues" / differences are much appreciated!
                              Juat want to weigh my options.
                              Thank you all!
                                I don't have CP or AA, but the disadvantages would be from my point of view as far as I've noticed:
                                Disadvantages CP / AA
                                • two devices, the display and the mobile phone
                                • Mobile phone gets very warm
                                • Skipping WP is not so easy
                                • Zooming is not so easy
                                • the CP / AA coupling causes problems
                                • no direct remote control with BT
                                • Type of operation wander over the display
                                • Display usually only horizontal
                                Mobile phone advantages
                                • all MyRouteApp functions
                                • Control via BT keyboard directly possible
                                • Navigation map zoom +/-
                                • Skip WP Double click (DC) right
                                • Call menu / search function
                                • etc.
                                • Mobile phone horizontal and vertical
                                My solution is an iPhone Xr in BMW Cradel with inductive charging, with the MyRouteApp with full function, the BT keyboard from Remotek One for direct zooming +/- and WP skip with DC right
                                M. Schrijver PieterG 2 Replies Last reply
                                  • etc.
                                  • First two points are valid. You could say it is a disadvantage. But that is a personal preference. AA/ACP has their advantages. Button sizes and functionality is setup for use on the road. The smartphone it is designed to use with the phone in your hand.
                                  • AutoSkip is big irritation point of mine. Regardless phone or AA/ACP. Because auto shouldn't exist at all. From that point of view. It isn't an issue.
                                  • Zooming is typical MRA issue. When using other navigation apps. Autozoom behave on AA/ACP exactly the same as on the phone.
                                  • AA/ACP connection issues are valid. But everybody has their own experience. So difficult to predict and rule out.
                                  • Most AA/ACP have touchscreens so BT remote controls are not necessary. Besides that. Controlling the app when riding is something you should avoid (safety issue). When the app works well, there is no need to control the app.
                                  • Type of operation? Do not know what you mean?
                                  • Horizontal navigation is the right one. Vertical navigation has no advantages at all. The map is tilted a bit in vertical position that's all. Only because people are used to hold their phone vertical, the option is there. Your view with your eyes is also horizontal. Never seen a person with 2 eyes on top of each other for vertical view
                                    @lenny-o @peter-zehentreiter
                                    Yes, but the app in vertical is already good !!
                                    Hint: Carpuride W712D Can be vertical and that as CP / AA Display
                                    Handy an der R1250GS im BMW Cradel
                                    Das W712D
                                      Das W712D
                                      PieterG
                                      PieterG
                                      PieterG
                                      #57
                                      Das W712D
                                      Nooo! First of all you need the W702BS or BS pro for BMW if you want Wonderwheel support. These BS models fit in the oem BMW navi cradle and therefore can only be mounted horizontally.
                                      Furthermore, Carpuride 7 inch models are blocking a bit of the view of your TFT screen when mounted horizontally, and if you mount the 712 (the one you do not need) vertically, it practically covers half of your TFT screen on a R1250GS and at the top it will rub against the windscreen....
                                      Nice setup you have with you phone in a phone cradle. I tried that once but the wireless charger was disturbing my key-free signal...
                                      And, more important to me, that way you have no touchscreen that works with cloves on, screen not bright enough in the sunlight and no Wonderwheel support...
                                        #58
                                        There is a solution to this... is still being tested
                                          PieterG
                                          PieterG
                                          PieterG
                                          #59
                                          Does it support the Wonderwheel? I don’t see a connector...
                                          And that doesn’t change the fact that you need a W702BS; otherwise, the Wonderwheel won’t work. (and I'm not shore the BS model can be used vertically; specs do not mention it...)
                                          • 4
                                          Òscar
                                          Òscar
                                          Ed Lauwerens 0
                                          Ed Lauwerens 0
                                          PieterG
                                          PieterG
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                            Mosimann
                                            Mosimann
