  4. nav 6 route problem
nav 6 route problem
4 Posts 4 Posters 414 Views 3 Watching
  • Charles Henson
    Charles Henson
    Charles Henson
    I have a 3000 mile route that will not load to nav 6 . I get only half the route i have tried several times as a track convert to route and directly as a route . it down loads ok from MRA but does not give me full route. I have not had a problem loading it to my Zumo xt .
      Perhaps the Nav6 isn’t capable of handling the entire 3,000-mile route. You could try splitting it up into smaller sections
      • Martin Woodford
        Martin Woodford
        Martin Woodford
        @charles-henson
        Could your NavVI have run out of storage ?
        Do you have other routes or tracks stored in your NavVI ?
        Have you cleared your travel history from tracks ?
        Do you have the correct map(s) installed ?
        I've just come back from a 5,500 mile trip. The NavVI held the total route and the 20+ individual routes it was broken into without any problem.
          Maybe it's because of a WP limit to the 50 pieces ... also with the VI .., I don't have the N6 anymore. Sometimes I know a calculation was not executed in the N6.
          Maybe check ... choose WP under Reduce Toolkits.. as a test with a copy of the route.
          Charles Henson
          Charles Henson
          Martin Woodford
          Martin Woodford
            2.4k
            2.2k
          • Seizoensafsluitingen
          • Altitude numbers size
            RainerT
            RainerT
