  4. IOS: App crashes 2-3 times a day (v5.1/5.2)
49 Posts 19 Posters 3.0k Views 7 Watching
  • Kerbelundefined Offline
    Kerbel
    I‘ve been riding through France the last 2 weeks and the app crashed 2 to 3 times a day. Not reproducable.
    All of a sudden I see my home screen without any freeze or so.
    Had to restart the app and the app asks whether to proceed navigation or not. With proceed the next button needs to be pressed to enter navigation mode. Then navigation worked as if no problem occured. No need to start the route from scratch. Tracklogs are working also properly.
    Sometimes 30min after start, sometimes a few hours after start.
    The routes (1 for ea day) have been created by my wingman on Basecamp and I‘m taking the lead with MRA. This worked without any problem for years.
    Setup:
    MRA on iphone 11, latest IOS, mounted on BMW Cradle.
    Anyone else experienced similar behaviour of MRA?
    BR
    Stefan
      Hi Stefan
      If I'm correct Corjan uses the same model phone for testing di that can't be the problem.
      I would send in the log files with a ticket to support di they can have a look at it
      Log files. Press on your avatar and scroll down. Press long on the version number
      • Cleoundefined Offline
        Cleo
        I was also using the app in France and had also some freezing issues, i use Apple CarPlay, the sreen blanked out and the arrow was still visible, i couldn't reset the because i was driving but after a while the map was visible again but still freezing. It almost look if the phone was out of memory. Iphone 15 Pro
        • RainerTundefined Offline
          RainerT
          I had exactly the same problem on my Samsung tablet. I use no CarPlay or other connection stuff.
          I’ve submitted a ticket with the logs. Corjan is on a well-deserved holiday, so it’ll take a bit of time.
          However, in my case it was version 5.1.
          • Aiello antoninoundefined Offline
            wrote last edited by Aiello antonino
            Same problem for me with iPhone 16 plus and CarPlay, I had written it in another discussion, same behaviour described above In the first post
              2 day trip, the CarPlay app closed by itself once on Saturday and once today... iPhone phone, restarted from CarPlay, it asked if I wanted to navigate the route that had just closed and I gave consent... all this before version 5.1 never happened...
              • Peter Zehentreiterundefined Online
                wrote last edited by Peter Zehentreiter
                Version 5.2.0-474
                Android
                Navigation via the app ONLY.
                Here’s a quick update on my 4 days in South Tyrol
                On Thursday and Friday, I used online navigation for a total of 860 km; the navigation kept cutting out, the phone’s home screen would appear, and I had to reopen the MRA to continue navigating.
                I’ve now had two instances where the app apparently failed to recognise or register a waypoint.
                For example, waypoint 10 appears in the top right-hand corner, but I’m already at waypoint 14. The navigation works, but waypoint 10 in the top right-hand corner cannot be skipped; the app doesn’t respond to any commands to skip this waypoint 10.
                On Saturday and Sunday we also covered over 800 km, but this time entirely offline.
                The app worked perfectly offline.
                Track recording was not enabled on any of the four days.
                BMW R 1250 GS
                DMD-NOR7E 7"
                SPC Universal mount
                Motorola Edge 40 "offline"
                Sena SLR 3
                Sena 50 R
                Marinus van Deudekomundefined Axel Härtlundefined 2 Replies Last reply
                  Kerbel
                  @peter-zehentreiter
                  the „frozen“ waypoint also occured on my trip and coul not be skipped.
                    Version 5.2.0-474
                    Android
                    @Peter-Zehentreiter during your first 2 days was there an indication that your internet connection was poor or nonexistant. And did you get notification that the mode was automatically changed to offline
                      Travellexxieundefined Offline
                      On my 72-days camper journey I had freezing moments every day.
                      • Ronnie Mooreundefined Offline
                        Ronnie Moore
                        Same here, multiple crashes per day when used all day.
                        I have had this happen on a iPhone 17 Pro Max and a iPhone 15 ever since the major rewrite. Luckily it crashes and then asks to continue the previous route, so it recovers easily.
                        Also, it crashed using CarPlay and without using CarPlay.
                          @Marinus-van-Deudekom No, there was no indication that there was no internet connection, nor was there any indication that the system had been temporarily switched to offline mode.
                          The error did not occur in the mountains either, but had already occurred during the journey in areas with good network coverage.
                          BMW R 1250 GS
                          DMD-NOR7E 7"
                          SPC Universal mount
                          Sena SLR 3
                          Sena 50 R
                          • Christian Feursteinundefined Offline
                            Christian Feurstein
                            I had a 9h trip yesterday without any problems, everything worked pretty well, even in the mountains with bad internet connection ...
                              @Peter-Zehentreiter van you send in the logfiles in with a ticket to support. Long pressing the version number will get you the files
                                @Marinus-van-Deudekom Unfortunately, NO,
                                I was out and about as a tour guide with a group of 10 people.
                                The focus was simply on keeping the system up and running 😉
                                BMW R 1250 GS
                                DMD-NOR7E 7"
                                SPC Universal mount
                                Sena SLR 3
                                Sena 50 R
                                  @Peter-Zehentreiter you can still get the logfiles. At least is you didn't push that button up till now
                                    @Marinus-van-Deudekom On top of that, I’m trying to convince my colleagues of the benefits of MRA.
                                    But I was constantly busy explaining the glitches to them and pointing out that we were working on fixing the problem.
                                    So creating a log file was the last thing on my mind 😎
                                    But I'll try right now.
                                    BMW R 1250 GS
                                    DMD-NOR7E 7"
                                    SPC Universal mount
                                    Sena SLR 3
                                    Sena 50 R
                                      Got it...shall I send to support or share it here in the forum?
                                      BMW R 1250 GS
                                      DMD-NOR7E 7"
                                      SPC Universal mount
                                      Sena SLR 3
                                      Sena 50 R
                                        @Peter-Zehentreiter Support, always.
                                        • Kerbelundefined Kerbel
                                          @peter-zehentreiter
                                          Stanisławundefined Offline
                                          @Kerbel said:
                                          @peter-zehentreiter
                                          in my case a temporary solution was stopping navigation and starting it at new (without restarting the whole application), the next waypoint was displayed correctly then. I observed such a problem once during my 7000 km trip.
                                          Staszek
                                          RetiredWingManundefined
                                          Adrian Avramundefined
                                          AWDC LAOundefined
                                          Thomas Neumeyerundefined
                                          Thomas Neumeyer
                                          Cleoundefined
                                          Cleo
                                          John 3sundefined
                                          John 3s
                                          Christian Feurstein
                                          RainerTundefined
                                          RainerT
                                          James Hubbard 0 0undefined
                                          James Hubbard 0 0
                                          Kerbelundefined
                                          Kerbel
                                          Axel Härtlundefined
                                          Axel Härtl
                                          Stanisławundefined
                                          Ronnie Moore
                                          • Skipping a Via point...
                                            Herman Veldhuizenundefined
                                          • Web App isn’t stable
                                            Richard 18undefined
                                            Richard 18
                                          • CarPlay route selection functionality
                                          • Veekeersinfo en omleiden
                                          • Library sync error
                                            Albert van den Elsenundefined
                                            supergundefined
