  4. Tracking
Tracking
6 Posts 6 Posters 151 Views 3 Watching
  • Larry Woomer 0 0undefined Offline
    Larry Woomer 0 0
    Does this app have a tracking function? I'm setting up a ride (it's my turn), I just want to go without any map help and have a app just track me and if I like it then I can save it to re-ride it with them as the leader at a later date. Thank you, Larry
    Rob Verhoeffundefined Brian McGundefined RainerTundefined 3 Replies Last reply
    • Larry Woomer 0 0undefined Larry Woomer 0 0
      Rob Verhoeffundefined Online
      Yes, it has a tracking function.
        Brian McGundefined Away
        @Larry-Woomer-0-0 as @rob-verhoeff says yes the "MRA Navigation app" does have a tracking function
        All you need to do is press the red dot button when your navigating, when it turns green it means it is recording your route, press again to stop recording & it will return to red
        Alternatively in the app you can go to "Settings > Navigation Settings > Functional" & under the section "Navigation Features" you have the option to "Automatically Start Tracklog"
          RainerTundefined Offline
          RainerT
          wrote last edited by RainerT
          Use free ride and activate tracking.
          Or turn on automatic start of tracking, so you use it in any case.
          But make sure to stop tracking manually and store your track.
          It is possible to import fotos into your track, BEFORE it is stored.
          Fotos with GPS-Information will be placed correctly.
          RT
          • Christian Feursteinundefined Offline
            Christian Feurstein
            Even with activated "automatic start of tracking" you have to start it manually in case of a simple A to B navigation.
            • RainerTundefined RainerT
              RT
              @RainerT automatic tracking will only work of you start a route. A2B routes require tracking to be switched on by hand.
              In case of free riding it's the same, turn it on
              Christian Feurstein
              RainerTundefined
              RainerT
              Larry Woomer 0 0
              • Account blocking issue
                Lluis Arasanzundefined
              • Why does route change when connecting to Android Auto?
                Herman Veldhuizenundefined
                Tony 13undefined
                Tony 13
              • Silverfox C1
              • Displaying POI
              • Real life verkeersinfo
                Alida Veenstraundefined
                Alida Veenstra
              • Update 5.2 - Persistent Map Items
