  4. MRA V5.2 (473) Topic new closures
15 Posts 3 Posters 81 Views 2 Watching
    Hey you,
    I once entered a manual blocking for me between WP 4 and WP 5, so with beginning and end, but the result is not as expected, I would have thought it would then run from WP 4 like the connection entered in red.
    • Why is the route changed so much... ?
    Link zur Route: Sehen Sie sich 'TeT Sperrungen ' in MyRoute-app an! https://www.myrouteapp.com/route/open/13656844
    • Marinus van Deudekom
      When did you enter that roadblock. Near to shapingpoint 4 or at home thuis at viapoint 1
        I would have expected the course so because the closure was only set later after WP 4 see after the branch, you could have followed the red line well or?
        It looks like the entire route between WP 4 and WP 5 is considered closed, then the route is no different, but the test lock was deliberately only set later after WP 4 ..
        Am I doing something mentally wrong or the MRA calculation?
          • started navigation to the test !!
          • At the test now at home, in the chair. Thought even then it works 😜, ... ??
            I’ve opened your route and when I tried to navigate the route from the start to waypoint 6 was volleerd white instead of Blue so there must be something else wrong with that route
              Weis actually only shows the previously planned course, since now the blue new one is calculated, the old one will then be white.
                  As soon as I enter the lock according to WP 4, MRA recalculates and blue turns white, incl. the new blue route below ...
                    Hey you,
                    @Hubert-Thoring The so-called "sofa-tests" are fun, but your proposed detour route also includes a road closure. I do think that factor of the roadclosure and the fact you're enyoing your sofa 😉 is giving you a route as the blue line suggested.
                      @rob-verhoeff : I don't understand your answer, and would expect us to get clarity..!
                        @Hubert-Thoring We clearly have a different sense of humor in Germany and the Netherlands! But testing from the comfort of your own couch at home doesn’t work with this feature! The route you’re being presented is completely justified and logical.
                          In other words, just put in roadblock at the location where such a roadblock is present
                            That means you should only use it when you are on site, so on the road, and then stand in front of the lockdown, is that how it is meant?
                            • So you can only use it properly on the go.
                            • So it can't be tested from the armchair (caustumly in the motorhome) just like that.
                              I think that's the message... Apparently, the algorithm is smart enough to take into account road closures that are recorded elsewhere on the map when calculating the detour.
                                @rob-verhoeff , @marinus-van-deudekom
                                I once changed the route, .. Link zu Angepassten Route
                                You were right there is probably a construction site see picture
                                • Strange translation
                                • Undo/Redo tool is hidden
                                • Crazy routing
                                  martin-phogel.de
                                  martin-phogel.de
                                  10.4k
