  4. The maps are out of date for large portion of the Balkans A few new motorways are not showing up building routes around disused roads
6 Posts 5 Posters 399 Views 3 Watching
  • Kevin OSullivanundefined Offline
    Kevin OSullivan
    The road maps are out of date for much of the Balkans
    New motorways, ring roads on and off motorway rams do not show, Lots of new road construction, When will new maps that are trust worthy be updated
    Thanks Kevin
    • Kevin OSullivanundefined Kevin OSullivan
      Thanks Kevin
      Rob Verhoeffundefined Offline
      @Kevin-OSullivan When de map-provider (Here) will choose to do so!
      • Bouke Entundefined Offline
        i have as backup osm maps. they are normely more up to date in east europe. but in MRA Next you can not use them. only in webplanner you can use then and make a track. In MRA Next you can drive a track but you do not get instruction... just follow the line.
        • Rob Veermanundefined Offline
          You might temporarily use another app that uses OSM maps. Some of these apps are free and OSM maps can be downloaded for free at several sites.
            Kevin OSullivan
            Unable to Make route from Turkiye to Batumi in Georgia MRA have any Georgia
              Brian McGundefined Offline
              @Kevin-OSullivan you might want to try the OpenStreetMap navigation app > Osmand for places a bit more off the beaten path
              The UI is a bit clunky but if you plan your routes in MRA & then transfer a gpx to Osmand for navigation, it works as well as most other navigation apps
              you do need to download to your phone all the maps for the areas you intend navigating
              these can be large & there are limits on how many areas/downloads you can get
              Bouke Entundefined
              Kevin OSullivan
                Lenny Oundefined
                Lenny O
              • Updated beta! 5.2.1 (486)
                Dave J 0undefined
              • Veekeersinfo en omleiden
                Bouke Entundefined
              • wrong routing
                John S Parryundefined
              • Play Knop in Route Lab
              • Geen gesproken aanwijzingen
                supergundefined
              • Request login credentials
                Aiello antoninoundefined
