  4. Starting a ride from Waypoint or Exact location
13 Posts 10 Posters 278 Views 4 Watching
  • Eric Colón 3 0undefined Offline
    Eric Colón 3 0
    I've been using the MyRoute app for a few months but have a question regarding starting from a nearest waypoint versu exact location. I've run into a few situations when the app wants me to "double back" to start the ride. Can someone please enlighten me and apologies for the MyRoute 101 question.
    RetiredWingManundefined Brian McGundefined 2 Replies Last reply
    • nomkoundefined Online
      It's simple (if this is what you mean and asked for:
      In my example:
      Waypoint 2 is a hard waypoint (routepoint) meaning you MUST pass this point to cintineu your journey.
      Waypoint 3 is a soft waypoint you can pass but you can also skip this point to continue your journey
      If you pass waypoint 2 and continue your journey, you will be rturned to wyapoint 2 although you might be very close to your endpoint (finish).
      | MRA Gold Member |
      | MRA Next + Kawasaki Z650 |
      • Jozef Malik 0undefined Offline
        Jozef Malik 0
        Hi, thank you for your reply. I'm adding the picture to explain better. Now, in the attached picture, the start/finish is where the checker flag is. But my accommodation is where I red circled the map, so ideally would like to start/finish the route there as opposed to riding all the way up to the start/finish checker flag.
        Some other vendors have a way to join the ride at the fastest possible route to it.
        Is there a simple way in myRoute navigation app to simply load the original GPX, but change start/finish on the fly, where I red circled?
        thank you
        joe
        • Eric Colón 3 0undefined Eric Colón 3 0
          @Eric-Colón-3-0 simply skip waypoint 1 and you're good to go.
            In MRA terminology, we’re talking about viapoints and shapingpoints.
            BMW K1600GT-P (2013) | Nolan N100-5 with Sena 30K
            iOS on iPhone 13 & 16 (mounted on Quadlock or AliExpress extention on BMW-cradle)
            Apple CarPlay in VW T-Roc
              Brian McGundefined Offline
              @Eric-Colón-3-0 all you need to do is zoom out the map so you can see the next point ahead of you on your route,
              press on this next point & it will become the start point for your navigation
              MRA will calculate the route from your exact location to this next piont after you have pressed it
              Normally navigate "Routes as Tracks" in Offline mode with Offline Maps
              • Jozef Malik 0undefined Jozef Malik 0
                thank you
                joe
                @Jozef-Malik-0, I all honesty, the previous comments are not going to help you... What I see is a track. You cannot change a track (at least not without completely redrawing it as a route). Assuming you will be navigating with the MRA app, what you CAN do is this:
                • just start the navigating the track as usual. You will be directed to the start point
                • long-press a point on the track, a bit ahead in the direction away from the start
                • Navigation will guide you to the end of the track just fine
                • From the end of the track, restart the track from the beginning until you are where you started
                Succes!
                Lenny Oundefined Jozef Malik 0undefined 2 Replies Last reply
                  Succes!
                  Lenny Oundefined Offline
                  Lenny O
                  Hi!
                  Would you please clarify what you mean here "From the end of the track, restart the track from the beginning until you are where you started".
                  Also, navigating the Track will still give you voice guidance as oppose to say Garmin that only gives you that for Routes, correct?
                  Thank you!
                  • Lenny Oundefined Lenny O
                    Hi!
                    Thank you!
                    @Lenny-O. What I mean is, if you reach the end of the track, you can simply restart the track from the beginning, to complete your journey to the point where you started. And yes, navigating a track will still give you voice guidance 😉
                    Lenny Oundefined 1 Reply Last reply
                      Lenny O
                      @Con-Hennekens Oh, I see... 🙂 You mean to get back to the accommodations point where the route ACTUALLY started! Clever!
                        Succes!
                        Jozef Malik 0
                        Con-Hennekens, thank you for the explanation in both threads, i am not sure how on earth I reply to completely different post. Maybe the moderator can move it to the thread i have started on this topic yesterday. Thank you
                        • ginoginoundefined Offline
                          ginogino
                          The correct start of navigation if you are already on the route depends on how you start the navigation, if you start the navigation from Android Auto (regarding Carplay I don't know) the app will take you back to the starting point, it doesn't matter if you are almost at the end of the route of many kilometers and many waypoints, it will always take you back to the starting point, if instead you start it from the app outside of Android Auto by activating the options "Start from the nearest waypoint" and "Use the current location" the navigation starts correctly from the nearest waypoint which is located in the direction of the end of the route, once started you can go back to using Android Auto.
                          coupe_vsundefined 1 Reply Last reply
                          • ginoginoundefined ginogino
                            coupe_vsundefined Offline
                            coupe_vs
                            @ginogino ((If, instead, you start it from the app outside of Android Auto by activating the "Start from nearest waypoint" and "Use current location" options, navigation will correctly start from the nearest waypoint, which is in the direction of the route's end.)) I'm sorry, I disagree with my opinion about this part of your answer. Last week we were discussing this point in another post on this forum... and it was concluded after much discussion that in both iOS and Android, if you activate the boxes you mention, you will indeed go to the nearest point on your route (but the nearest point isn't always in the direction of the route's end). Sometimes the nearest point is very close to you (but behind you), and therefore you will go backward on your route and not towards its end... (I suggested this as an idea if it might be of interest for future updates of the navigation app)... but the only solution offered to me was that I had to manually navigate through the previous waypoints or zoom out and go directly to the next point towards the end of the route) Both solutions don't convince me. Normally, a browser should redirect only from your position to the next point (not to a previous one you've already passed) simply because it's closer.
                            coupe_vsundefined
                            coupe_vs
                            Lenny Oundefined
                            Lenny O
                            ginoginoundefined
                            ginogino
                            Eric Colón 3 0
                            Jozef Malik 0
                            • Feature request - enhanced speed camera alerts
                              Aiello antoninoundefined
                              4.0k
                            • Pondje invoegen
                              Leike Lodiersundefined
                            • How to Navigate Route as a Track?
                              coupe_vsundefined
                              coupe_vs
                              2.6k
                              2.8k
                              3.0k
                            • Starting a ride from Waypoint or Exact location
                              coupe_vsundefined
                              coupe_vs
                            • Gas stations...
                              coupe_vsundefined
                              coupe_vs
                            • MRA 5.1.0 (462) iOS - Sharing via WhatsApp is not possible
