  3. Frustrating MRA Navigation App - tries to navigate me back to the start if I stop.
17 Posts 8 Posters 3.9k Views 3 Watching
  • HABVEN aka MrMRA
    Do you close the app during the pause?
    David Rudgley MotoCon 2 Replies Last reply
      David Rudgley
      David Rudgley
      David Rudgley
      @Hans-van-de-Ven-MRA-Master No, often it's me removing the phone from the mount with the app still running and turning the display off while it's either in my pocket of in storage
      MRA Gold Planner + App + Navigation Next user
      Android Pixel 10 Pro Fold
      TomTomGo as backup
      KTM 1290 Super Adventure S
      Quad Lock + Phone + Carpuride W702
      2026 Kawasaki Z900 RS
      Beeline Moto II
        @Hans-van-de-Ven-MRA-Master said in Frustrating MRA Navigation App - tries to navigate me back to the start if I stop.:
        I recognize this. I am not sure if it has been corrected already, But I think that even with NOT closing the app, but just restarting the route, that option defaults back to "Beginning of route". I have made comments about this before, to make that option an application option instead of a route option (that seems to be not permanently).
        Kudee 1 Reply Last reply
          Kudee
          Kudee
          Kudee
          @Con-Hennekens When you restart the route, the app will take you to the first point. However, you can see where you are and then select the next WP via "Edit route settings" as explained above. Maybe later it will be possible to select the WP directly. lg Kudee
          • Kudee Kudee
            David Rudgley
            David Rudgley
            David Rudgley
            @Kudee I will be using the app again on a tour this coming weekend so I will use the route option navigate to closest WP or specific WP # and load the maps into TomTom Go as a back up
            TomTomGo as backup
            Beeline Moto II
            • Kudee Kudee
              @Kudee said in Frustrating MRA Navigation App - tries to navigate me back to the start if I stop.:
              Yes, that's what I am saying. So the option that says "start at closest waypoint" is not permanent, and therefore meaningless. It should be an application-options, not a route-option and certainly not one that defaults back to what you did not choose before.
              Albert Renting 1 Reply Last reply
                Albert Renting
                Albert Renting
                Albert Renting
                @Con-Hennekens What I do during a stop for lunch or whatever other reason is pause the route and when I continue just touch the screen to restart and the route is displayed exactly where it was paused.
                I don't stop the route or anything, just pause it and it works fine for me everytime.
                • Roundabout
                  Roundabout
                  Roundabout
                  When using a ride I made, saved as a Harley GPX, and then use in a Harley Boom Box and I have this problem, when I get back on bike I look for the ride in the boom box, find the ending waypoint and click on it and it works every time
                  • Albert Renting Albert Renting
                    @Albert-Renting said in Frustrating MRA Navigation App - tries to navigate me back to the start if I stop.:
                    I tend to check the route, where we are exactly and where shortcuts or detours are possible. Therefore it is not possible to not stop the route. You should be able to restart aroute given the available options to do so, but they do not work as intended. That's called a bug 😉
                      Albert Renting
                      Albert Renting
                      Albert Renting
                      @Con-Hennekens Even then it is possible. Start the desired route and then skip to the next waypoint from the location where you are at and you will be guided first to that next waypoint and then the route will be followed.
                        @Albert-Renting, Yes Albert, but that is not what you would expect from a feature called "Start at closest waypoint" now, is it? I have been using Navigation from the get go, so I know how it works 😉
                        • David Rudgley
                          David Rudgley
                          David Rudgley
                          This wouldn't be an issue if the App was stable, reliable and didn't reset the route numerous times during a ride. I will continue to use TomTom Go app until I can be confident that these issues have been fixed, fingers crossed that the new version of the MRA Navigation App is an improvement on the current build.
                          TomTomGo as backup
                          Beeline Moto II
                          David Rudgley
                          David Rudgley
                          Kudee
                          Kudee
                          Spili
                          Spili
                          Albert Renting
                          Albert Renting
                          Roundabout
                          Roundabout
                          • Kaart niet zichtbaar
                            Bé Jeuring
                            Bé Jeuring
                          • Xpert overlay not clear
                            Corrado Miniati 0
                            Corrado Miniati 0
                          • Google maps
                            Ed Bos 0
                            Ed Bos 0
                          • Trains like Ferries?
                            Corrado Miniati 0
                            Corrado Miniati 0
