  4. App behaviour when in offline mode at a construction site
30 Posts 7 Posters 5.4k Views 4 Watching
    With route as route you will see no difference. MRA should handle this offline just as good as online.
    With route as track there can be difference but i don't know this feature good enough. I use it almost never.
      @M.-Schrijver said in App behaviour when in offline mode at a construction site:
      Me neither... that's why I'm asking
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
      BMcG 1 Reply Last reply
        @Peter-Zehentreiter you have probably already seen this MRA tutorial video "Route Navigation Versus Track Navigation" but just in case you missed it 😀
        • BMcG BMcG
          @Brian-McG Yes, I’m familiar with this video, and I also understand how it works – it’s simply brilliant.
          The reason I’m considering using this option more often is, that due to some outdated traffic updates from Here, I’m sometimes receiving information I don’t actually want.
          Thanks for the tips from the community 👍
          I’ll just give it a go.
          A Bavarian would say:
          "Schau ma moi, dann segn mas scha"
          BMW R 1250 GS
          DMD-NOR7E 7"
          SPC Universal mount
          Sena SLR 3
          Sena 50 R
            @Peter-Zehentreiter said in App behaviour when in offline mode at a construction site:
            You can also simply disable all traffic options in your settings - functional tab if you don't want that info.
              @Con-Hennekens said in App behaviour when in offline mode at a construction site:
              Hi Con, I’m not sure if this setting will solve my problem?
              A week ago on Sunday, I wanted to drive this route, but the problem started at the spot I’ve marked in red: the app refused to let me continue, or rather, kept telling me to turn back because the route was supposedly closed.
              Ultimately, according to the app’s instructions, I was supposed to drive via Cortina d’Ampezzo, even though the roadworks had already finished.
              I’ve just disabled all traffic settings in the app and started the route; the closure still appears on the map, and I don’t think the app will ignore the closure at that point because of that.
              It may well be that I no longer receive any information, but the route through the roadworks will still be blocked.
              I am therefore looking for a practical solution to this problem.
              https://www.myrouteapp.com/de/social/route/13124967?mode=share
              Screenshot 2026-04-23 100413.png Screenshot 2026-04-23 100320.png [link text](link url)
              BMW R 1250 GS
              DMD-NOR7E 7"
              SPC Universal mount
              Sena SLR 3
              Sena 50 R
              • MotoCon
                @Peter-Zehentreiter, Ah yes... We were discussing a similar thing yesterday amongst Alpha Testers. My theory is that some longer roadblocks are being registered in the map itself instead of through traffic info. A bit like seasonal closures, but I cannot get confirmation. Is the closure not relevant anymore? Try to update your maps and see what happens. Please report back, thanks!
                  You mean the offline maps?
                  BMW R 1250 GS
                  DMD-NOR7E 7"
                  SPC Universal mount
                  Sena SLR 3
                  Sena 50 R
                    @Peter-Zehentreiter, yep
                      @Con-Hennekens I’ve updated the maps; I think it’s now version 2.18.
                      The glitch was practically gone by last week.
                      Attached are 4 screenshots…
                      1x Route with online traffic information enabled
                      1x Route with offline traffic information disabled
                      1x Track with online traffic information enabled
                      1x Track with offline traffic information disabled
                      offline Route as Route Traffic settings off.png online Route as Route Traffic settings on.png Route as Track online Traffic settings on.png Route as Track Traffic settings off.png
                      BMW R 1250 GS
                      DMD-NOR7E 7"
                      SPC Universal mount
                      Sena SLR 3
                      Sena 50 R
                      • MotoCon
                        @Peter-Zehentreiter, It is clear that the closure in your case is still there after updating. We have another example at hand where the closure indeed disappeared after a map upgrade. That seems to support my theory that closures sometimes are in the map data instead of the traffic info.
                          Hi @Peter-Zehentreiter is the shared route "Marostica_Lienz" just an example to illustrate the issue or is this the route you plan to use?
                          This error maybe because for this route the avoidance "Highways" is enabled
                          the aviodance maybe limiting the options that the routing calculation can use when trying to recalculate around the construction
                          • BMcG BMcG
                            @Brian-McG Both... it’s to show how road closures behave with the various settings on the map and in the navigation system.
                            I drove the route the week before last.
                            Enabled highways aren’t relevant here, because there aren’t any highways in this area.
                            The option was included because, shortly before the destination, a motorway might have been a viable alternative.
                            BMW R 1250 GS
                            DMD-NOR7E 7"
                            SPC Universal mount
                            Sena SLR 3
                            Sena 50 R
                              To come back at this shortly:
                              I think we must reconsider this. I think what we see is a caching method in action. Map updates do not seem to influence closures afterall. App updates however do. So at an app update apparently the cache is deleted.
                              • Startpunt wijzigen
                                Giancarlo e
                                Giancarlo e
                                Ed van Klink
                                Ed van Klink
                              • Route exporteren uit beta
                              • V6 - Track Navigation
                              • Info on MyRoute-app's POI
