  3. New device …. how to change registered devices?
4 Posts 3 Posters 656 Views 1 Watching
  • silberfuchs67
    silberfuchs67
    silberfuchs67
    I just received my new Android device. What is the procedure to register the new device and „delete“ the old one to use the MRA App? I have another Apple device which I want to keep so I need to avoid a third device.
    Thanks for your support.
    • silberfuchs67 silberfuchs67
      @silberfuchs67 I would do it as follows.
      On the old device, go to Settings, my Devices, and sign out the existing device there.
      Then install the MRA app on the new device, and this device should then be registered in place of the old one.
      To be on the safe side, though, I’d send a quick message to support to make sure the account isn’t blocked.
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
      • silberfuchs67
        silberfuchs67
        silberfuchs67
        Thanks for your support - this was exactly the way it is working 👍
        • Con Hennekens
          A third device will NEVER be a blocking problem, it is the fourth device in a month that does that. Adding a third device will just show you the "my devices" window where you can dismiss one of your devices.
          silberfuchs67
          silberfuchs67
            Floris v
            Floris v
            4.0k
          • Altitude numbers size
            JosepD
            JosepD
          • Points of interest
          • Seizoensafsluitingen
