  4. MRA V5.0.3 (449) The contrast is not sufficient
29 Posts 9 Posters 339 Views 5 Watching
    So your screen has a glare in the sun?
    Cannot do much about that πŸ™‚
    Reading the rpm on your bmw display is hard too with that lighting πŸ˜‰
    @Corjan-Meijerink said in MRA V5.0.3 (449) The contrast is not sufficient:
    1. Anti-glare film on the screen helps a lot. About 15 Euros.
    2. Wong + 'Roads only' option in Map Style is quite high contrast (yellow roads on light grey background in light mode)
      I can't really take that first
      I use that but the contrast is still missing
        The contrast is unfortunately chosen...
        The small white streets are not really good to spontaneously conquer a beautiful little street unplanned...
        Direction stretched by 180"
        • ConiKost
          ConiKost
          ConiKost
          I also would like to add, as in comment #19 from Hubert, that those small white roads are really not very good to see. Maybe a litte bit different color could already help to make them see better.
          Shiny!
          • Steve 2v
            Steve 2v
            Steve 2v
            Adding my support to this - the low contrast in the standard maps does make me keep looking at other apps like scenic or OsmAnd
            • Steve 2v Steve 2v
              @Steve-2v, Tried the different map-styles yet?
              Hubert Thoring Steve 2v 2 Replies Last reply
                @Con-Hennekens : They all behave the same, the matching map with more contrast is missing to be able to see the small streets well ...
                  Steve 2v
                  Steve 2v
                  Steve 2v
                  Yes, tried the different options. Ideally a map style like the DMD2 high contrast would be perfect. The use of light white roads on any of the maps that identify different road classes with colour like Wong for example are just hard to see. If they were grey (no other changes) i think it would solve a lot of the issues.
                  I’ve ended up using a combo of DMD2 for most of my riding, but still use MRA now when I need traffic info to be factored in.
                  • Guzzist
                    #25
                    I confirm too - all 3 possible map styles do have too les contrast; the colour are too pastel.
                    Suggestion for development: a config file like GARMIN has, by which a user can modify all used colours. Easiest way is in that, to alter the colours for street borders to a darker colour.
                    • MotoCon
                      While I can agree that the map could use a high contrast and a more topological view, I think having it completely customizable is too much complexity almost no one uses. Also Garmin users seldomly use those features.
                        @Con-Hennekens : To your statement, do you think this will somehow help, ...
                        The fact is that the roads without route and sun are not really easy to see on the display, if I stubbornly follow a planned route, it almost doesn't matter what else is shown there .. since the route dominates strongly blue πŸ‘‹βœ…
                        Baltus 1 Reply Last reply
                        • Guzzist
                          ...for example, I can't understand if land areas are in color of grey pattern - why city names are in grey font color too? Why not in black to get more contrast?
                            Baltus
                            Baltus
                            Baltus
                            wrote on last edited by Baltus
                            #29
                            @Hubert-Thoring said in MRA V5.0.3 (449) The contrast is not sufficient:
                            I don't agree with that, because you also want to see cross roads!
                            ConiKost
                            ConiKost
                            Baltus
                            Baltus
                            Steve 2v
                            Steve 2v
                            • Opstarten app in Android.
                              Beemerfrankie
                              Beemerfrankie
