  4. Different paths between TT and Here algorithms
6 Posts 4 Posters 661 Views 2 Watching
    Corrado Miniati 0
    All things being equal on the Route Planner, Here takes me down a route that isn't the fastest, while TT shows me the correct route.
    Why does this happen?
    • Leike Lodiersundefined Offline
      They are different card manufacturers and there for the roads style can be different. You can use the compare or the disable seasonal closing option in the right menu to see if you can bring the routes together till they are the same. When you use the openstreetmaps you will see they have a different route. It's all in the design of the road and the class the where given.
        Corrado Miniati 0
        Hi Leike, thanks for the feedback.
        In fact, with Here by activating the "disable seasonal closing option," the route aligns with the TT, which was correct because it was traveled yesterday and was open.
        In this case, Here's seasonal closing's database isn't up to date.
        • Aiello antoninoundefined Offline
          The same problem you have with Garmin navigators, except that here you can disable seasonal closures, while you can't do this with the ZUMOs...
            Corrado Miniati 0
            the fact that it is activated in itself would not be a problem if it were updated and reliable, but it creates discomfort if it is not
            • RainerTundefined Offline
              RainerT
              Activate the Traffic layer and Zoom in. You will be able to recognize the reason for the closure. In Most cases.
              Rt
              RainerTundefined
              RainerT
              Corrado Miniati 0
              • Manual Zoom
                Koen Vandecauter 0undefined
                Koen Vandecauter 0
              • Back from vacation
                Mopetenpitundefined
                Mopetenpit
                1.3k
              • Wunderlinq mive keft
