  3. Preview
Preview
13 Posts 5 Posters 1.6k Views 2 Watching
  • Iain Cochrane 0 Offline
    Iain Cochrane 0
    Evening All, just a quick question, I've been watching the last two online trainings which spurred me on to using the app.
    I did at the weekend and it all went horribly wrong. I thought I had created the perfect route, but from early on it kept telling me to turn around πŸ€·β€β™‚οΈ
    I have no idea why this happened, but I need to investigate so I don't have a repeat performance later in the year when further from home.
    Is there a way I can get a demo of my route ?
    That way I can probably figure out where I went wrong ?
    Cheers,
    • Iain Cochrane 0 Iain Cochrane 0
      Cheers,
      Rob Verhoeff Offline
      @Iain-Cochrane-0 Reading your question, I suspect you're being routed back to the starting point of your route. That starting point is always a via point (hand symbol). You must visit that point obligatorily. Since there are no other noticeable "symptoms" in your question, this is what it makes me think. I think that starting point is placed too close to the location where you are at the moment you start navigation. It's better to place that starting point a few hundred meters away from the actual location where you are at that moment! The navigation will then automatically guide you over the starting point.
      Iain Cochrane 0 1 Reply Last reply
      • richtea999 Offline
        richtea999 Offline
        If you share the route here by making it public, there may be something obvious that somebody will spot (using 'via's rather than waypoints, the wrong routing engine compared to the device, etc, etc).
        Adjust your exact home address if its in the route - for privacy, of course.
          Iain Cochrane 0
          @Rob-Verhoeff
          Many thanks Rob, that makes sense, and maybe I just made the start point too close.
          I will try the route again at some point with a relocated start point.
          Cheers,
          • richtea999 richtea999
            Iain Cochrane 0
            @richtea999
            Many thanks for your quick reply,
            Here'sthe route,
            https://www.myrouteapp.com/en/social/route/12930170?mode=share
              @richtea999
              Here'sthe route,
              @Iain-Cochrane-0 Since your route only contains two via points (start and end), I suspect that you somehow skipped the starting point, and the navigation therefore keeps trying to send you back until you have actually β€œhit” that point.
                Iain Cochrane 0
                Thank you Rob, I will move the start point and do the route again soon.
                Cheers,
                • Leike Lodiers Offline
                  Make shore youre gps device is fully started before you leave the starting point. Move youre starting point a bit further away from where you actually start to avoid you miss it when you leave.
                  • Leike Lodiers Leike Lodiers
                    Iain Cochrane 0
                    @Leike-Lodiers Hi, some good points raised here from my question. I think my navigation device was fully booted up, but perhaps not πŸ€·β€β™€οΈ. I will move the start point a little bit further away and re run the first part of the route. I can do that quite easily without having to redo the entire route.
                    Thanks everyone for their input.
                      @Rob-Verhoeff
                      Cheers,
                      @Iain-Cochrane-0, What @Rob-Verhoeff said indeed. If you are on your way and this happens, simply skip the waypoint.
                        Iain Cochrane 0
                        That's interesting, how do I do that ?
                          @Iain-Cochrane-0, press the waypoint number tile in the upper right corner of your phone. In case you are using a Android Auto or Carplay (which is not mentioned) you will need to open the menu to find the skip button.
                            Iain Cochrane 0
                            Thanks, I will explore that option.
                            Iain Cochrane 0
                            Iain Cochrane 0
                              1.6k
                              15.7k
                            • HERE maps updates
                            • bundel purchase
                              veghelvan 0
                              veghelvan 0
                            • New forum section about exports!
                              1.1k
