Adjusting start point surrounding routes
Wouldn’t it be nice if you could change the starting point of a surrounding routeand still be able to drive the whole route?
When I select point 41, which is the closest to my location, I don’t get the first part of the route anymore. On the PC when you change the starting point the whole route is renumberd.
The startpoint you mentioned is something else than a startpoint of a route.
In your example you tell MRA navigator where you want to pickup the route to ride it to the existing endpoint.
What you ask is selecting is different point as the starting point for the whole route. This also means moving the actual endpoint (in case of a roundtrip).
This is normally done in the planner. Which is also accessible from the app. -
I want to tell MRA to go to the nearest point on the route and then start the route from there. Should be possible IMO.
@Rolf-Engelsman After tapping Navigate, tap Routing settings and here you can choose to start from nearest waypoint.
@Rolf-Engelsman what you suggest is indeed not possible.
You cannot select a different starting point and let the app automatically complete the loop for you
I do think this would be a great addition!
Perhaps I can add this at some point
@Rolf-Engelsman
So I don't find it a problem, just the WP41 as Einstig in the route goes at the push of a button, then just drive the route to the end of the route, then stop briefly, stop the route in the app and finish completely. Now select again and restart this route with WP1 then continue to WP41, and already everything is just gone crazy without making a big find. Best regards
This moght seem far fetched for some, but I don't think it is. It would really be nice to be able to to start a route from let's say RP23, while making the loop until you reach RP23 again. I just wonder how that's going to go with routes that do not loop....
@Con-Hennekens said in Adjusting start point surrounding routes:
Then the question does not arise
New users have to get to know the app, many drivers are more relaxed and have a solution either way.
@Hubert-Thoring said in Adjusting start point surrounding routes:
What question?
As far as I know there is no parameter to indicate a route being a loop. It can only determined by an assumption of start and finish being close to each other.
