  4. Restart of Route
Restart of Route
3 Posts 3 Posters 655 Views 3 Watching
    Hi, I am not sure if this was suggested already. But I would like to have the restart of an route a bit different.
    Following scenario, I have loaded a route to navigate and think, shit I want this without highway. So I have to stop the route, decline the restart, and then re-locate the route in the directory to avoid the highway when starting it again. However, if I restart the route after stopping it, this option isn't even available. The "avoid" option should be available after the restart prompt, essentially a step further along the process.!
      @Jörgen
      Between the function, click on Navigate and before clicking on Start comes the option at the bottom of the menu, but only to avoid if you use the HERE map for a route, with route track this is not offered ....
      Zwischen der Funktion, Klick auf Navigieren und vor Klick auf Start kommt die Option unten im Menü, zu Vermeidungen aber nur wenn Du die HERE Karte für eine Route nutzt, bei Routen-Track wird dieses nicht angeboten ….
        @Jörgen
        @Hubert-Thoring said in Restart of Route:
        Not if you use "resume" option. That is specifically to resume the route "as is", therefore nothing is changeable.
        That cannot be offered if the route was made in a non-HERE map, since those are automatically navigated as track.
          Alderweireld Rudi 0
          Alderweireld Rudi 0
          Hanza 0
          Hanza 0
        • Weather as a service
          Andy Smith 5
          Andy Smith 5
        • Lane view in Android Auto
          denWINNE
          denWINNE
