  4. Link to other User not working
4 Posts 3 Posters 389 Views 2 Watching
  • Jörgenundefined Offline
    Hi, I have a list of user of our club, when I click on one off the links, I am taken to my personal profile, not to this user.
    I noticed the link will be changed when used.
    This link:
    https://www.myrouteapp.com/profile/home/1347380
    will change to this:
    https://www.myrouteapp.com/en/profile/home/1347380
    For some reason the /en will be added.
    If I manually remove this /en , I get to the profil of the user I want.
    How is this possible?
      Not sure and I can investigate it.
      But that said, I would never recommend manually changing links 😉
      • Jörgenundefined Jörgen
        This link:
        @Jörgen, Yes I notice the same behaviour. Likely the "en/" refers to English language. A link to a profile should not have a language designation, since the language does not depend on the profile, but on the user looking into the profile. So I suspect a little language misconfiguration that was left unnoticed until your efforts t use profile links on your website 😉
          Thank you for confirming.
            AWDC LAOundefined
            1.6k
          • In eens verdwenen mogelijkheid om 3 apparaten te gebruiken als Gold member?
            AWDC LAOundefined
          • Snelheidsweergave in spit screen modus carplay
            Remco vd P.undefined
            Remco vd P.
          • Probleem met ANDROID in de wagen.
          • Here map errors
            Tom Grzelinskiundefined
            Tom Grzelinski
            1.2k
          • Siri gebruiken met CarPlay
