  4. Detours are displayed differently in CarPlay
10 Posts 3 Posters 175 Views 2 Watching
  • Jörgenundefined Offline
    Hi, due to an traffic jam, the route had a detour, that was displayed different on CarPlay then on the display on the iPhone.
    When I saw this on CarPlay, I was confused what route to take?
    Then I switched on the iPhone and saw a different view.
    It shows the detour and the reason for the traffic jam.
    So why is the detour white on iPhone and which route should I take on CarPlay?
      @Jörgen
      As far as I know, the view means:
      A: Mobile Phone
      • White route is the originally calculated route from the planning (or the track route)
      • Blue is the currently calculated route at the start of navigation, which you are then supposed to follow, depending of course on your basic navigation settings!
      B: CarPlay Display It seems that the CarPlay display doesn't differentiate between these?
      • The display actually tells you to continue driving and turn right in 11 km, which also corresponds to the view on the mobile phone, even though the phone at least shows increased traffic.
        Any idea why the detour is displayed on CarPlay also in blue?
          Hi Jürgen,
          I'm afraid I can't help you any further here. Maybe try setting it up under CarPlay. Link Klick
          @Corjan-Meijerink : It would be good to know what the cause might be and whether it can be fixed, as Jörgen described above.
            @Jörgen : Do you already have an answer to your problem?
              Has this error been fixed ?
              https://forum.myrouteapp.com/post/72842
                No!
                It is probably difficult to reproduce.
                  just for the books. This issue still exists. A little bug that still confuses me during use of CarPlay.
                  In CarPlay
                  On iPhone
                  The unused white line route is displayed in CarPlay also in blue.
                  @Corjan-Meijerink is this noticed? Then I can stop nagging. 😕
                  • Jörgenundefined Jörgen
                    In CarPlay
                    On iPhone
                    @Jörgen, Is that white line actually part of the route (start and finish at the same location)?
                      The white line is the original calculated route from A to B. During the detour (or in the last case), I drove a different route; the app made a new route (seen in blue).
                      The old one is then displayed in white on the phone.
                        richard 3vundefined
                        richard 3v
                      • Crashes na update
                        Jan Weerheimundefined
                        Jan Weerheim
                        Reinhard Punzundefined
                        Reinhard Punz
                        3.1k
                      • Duizend bochten
